MHB How are Earthquake Magnitudes Calculated on the Richter Scale?
The Richter scale calculates earthquake magnitudes using the formula R(I) = log(I/I0), where I is the amplitude recorded on a seismograph and I0 is a reference amplitude. For amplitudes of 1,000,000I0 and 1,000,000,000I0, the correct calculations yield positive values, indicating stronger earthquakes. The initial suggestion of negative values was incorrect, as the scale measures relative strength, not absolute amplitude. The 100km distance mentioned is irrelevant for the calculation since I0 cancels out. Understanding the logarithmic nature of the scale is crucial for accurate magnitude assessment.
arl2267
The magnitude of an earthquake, measured on the Richter scale, is given by
R(I)= log(I/I0)
Where I is the amplitude registered on a seismograph located 100km from the epicenter of the earthquake, and I0 is the amplitude of a certain small size earthquake. Find the Richter scale ratings of earthquakes with the following amplitudes:
a) 1,000,000I0
b) 1,000,000,000I0
Okay so would the solution be
log(100/1,000,000)= -4
log(100/1,000,000,000)= -6
Mathematics news on Phys.org
R(I)= log(I/I0)
a) 1,000,000I0
b) 1,000,000,000I0
The value of 100km is meaningless in this context - ignore it. The question is giving you values of $I$ in terms of $I_0$ which means the latter will cancel out giving a number.
Your values should be positive. If you consider it logically an earthquake 1 million times stronger than a reference will be larger on the Richter scale than said reference quake.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
