How are essential oils affected by an alkaline medium?
  • Thread starter peppertea
  • Tags
    Medium
In summary, the alkaline medium and high temperatures used in soap-making can both affect the properties of essential oils, with the alkaline medium causing more breakdown.
peppertea
Hello! I've been searching this on the internet but found no relevant results, so maybe one of you can help me.
How are essential oils and their properties affected by the very alkaline medium during soap-making? I suppose some of their components are lost, some remain, but in what proportion? And is the alkaline medium worse or better for keeping their properties then high temperatures (let's say 80 degrees Celsius)?
(wondering how much is lost when making cold process soap, versus making hot-process- speeding up saponification- and only after the mixture is completely saponified and the pH level is down again adding the essential oils)
Thank you, and I'd appreciate any help, since this is troubling me for a while now!
Happy holidays!
Chemistry news on Phys.org
The alkaline medium used in soap-making can cause some of the components of essential oils to break down. This is why most soap makers will wait until saponification is complete before adding essential oils, which reduces the amount of breakdown that occurs. The high temperatures used in hot process soap-making can also cause some breakdown, but the alkaline nature of the soap mixture can cause some components to break down more quickly than they would at lower temperatures. Generally speaking, the higher the temperature, the more breakdown of essential oil components that can occur.
FAQ: How are essential oils affected by an alkaline medium?
How does an alkaline medium affect the potency of essential oils?
An alkaline medium can have a significant impact on the potency of essential oils. The high pH level of an alkaline environment can cause the oils to break down and lose their effectiveness. This is because the chemical composition of essential oils is sensitive to changes in pH, and an alkaline medium can alter the structure of the oils, reducing their potency.
Can essential oils be used in an alkaline solution?
Yes, essential oils can be used in an alkaline solution, but it is important to note that their potency may be affected. As mentioned before, the high pH level of an alkaline medium can cause the oils to break down and lose their effectiveness. It is recommended to use a small amount of essential oil in an alkaline solution to minimize any potential loss in potency.
Are there any essential oils that are more resistant to alkaline environments?
While all essential oils can be affected by an alkaline medium, some may be more resistant than others. Generally, oils with a higher concentration of sesquiterpenes, such as sandalwood and patchouli, tend to be more resistant to alkaline environments. However, it is still important to use caution when using these oils in an alkaline solution.
How can I prevent essential oils from losing potency in an alkaline medium?
To prevent essential oils from losing potency in an alkaline medium, it is important to dilute them properly. Diluting essential oils with a carrier oil or using a smaller amount of oil in an alkaline solution can help minimize any potential loss in potency. Additionally, storing essential oils in a cool, dark place can also help preserve their potency.
Can the pH level of an alkaline solution affect the therapeutic benefits of essential oils?
Yes, the pH level of an alkaline solution can affect the therapeutic benefits of essential oils. Essential oils are most effective when used in their natural, slightly acidic state. When exposed to an alkaline environment, the chemical composition of the oils can change, which may impact their therapeutic properties. It is important to maintain the proper pH level when using essential oils for therapeutic purposes.
