How are force and pressure related in a hydraulic system?
In summary, the water will flow from the small syringe to the big syringe due to the equal pressures.
What do you think?
I think the handle of the big syringe will push in the handle of the small syringe. In other words, water will flow from the small syringe to the big syringe.
I agree.
However, I was initially confused because it seemed like a paradox. Do you take the pressures inside to be equal or the force on the handles to be equal? I think I have it sorted out now. I just wanted to post it since I thought it was a neat problem that I found on the Dot Physics blog.
The forces must be equal and opposite. Therefore, the pressure will be higher in the narrower syringe, and thus water will move away from this region.
Also, if you assume the pressures are equal, then the water will exert a bigger force on the handle of the big syringe than on the handle of the small syringe, again leading to the same result.
That all depends on the frictional forces of the pistons and the head loss of the water through the fittings. Those forces may balance out the difference in applied pressures. Without knowing those factors and with how much force the syringes are pushed together, you can't solve this problem.
IMO It seems correct to say that statically the pressures are equal while dynamically the forces are equal. So, if you think we are proceding by steps, each one being composed by one state (static) and one process (dynamic) then you have a picture of the phenomena.
I just feel the absence of a nice justification for this manouvre.
Best wishes
DaTario
FAQ: How are force and pressure related in a hydraulic system?
What is the difference between force and pressure?
Force is a push or pull on an object, while pressure is the amount of force applied over a specific area. In other words, force is a vector quantity and pressure is a scalar quantity.
How do force and pressure affect objects?
Force and pressure can cause an object to change its motion or shape. A greater force or pressure can cause more significant changes to the object.
What is the formula for calculating pressure?
The formula for pressure is pressure = force/area. This means that pressure is directly proportional to force and inversely proportional to the area over which the force is applied.
Can pressure be measured directly?
No, pressure cannot be measured directly. It is usually measured using tools such as a pressure gauge or a barometer, which measure the force applied by the pressure on a specific area.
What are some real-life examples of force and pressure?
Some common examples of force and pressure include pushing a door open, the weight of an object on a surface, and the pressure of water on the walls of a swimming pool.
