High School How are fractures in airplane structures detected by ultrasound?
Ultrasound is used to detect fractures in airplane structures by reflecting sound waves at interfaces where there are changes in material properties. While ultrasound can travel through solids, it encounters difficulty exiting into air, leading to significant reflection at fractures. This reflection occurs due to differences in acoustic impedance between materials, which causes energy to be absorbed or reflected. The discussion clarifies that the assertion that ultrasound cannot travel through air after passing through solid is misleading; rather, most energy reflects back, indicating a crack's presence. Understanding acoustic impedance is crucial for effective ultrasonic testing in aviation.
pgirl1729
TL;DR
How does fractures in airplanes detected by ultrasound?
For applications of ultrasound, detecting fractures using ultrasound is listed in one of my textbooks. According to that, ultrasound cannot travel through air right after it travelled through solid parts of the plane. Therefore if there was a fracture, the sound was supposed to be reflected back. How does it happen exactly? I don't have much knowledge about it. Is it because solid has the ability to cope with the high frequency of ultrasound, but air doesn't? apparently making it go back?
Likes sandy stone, russ_watters and pgirl1729
I think the key reference in Baluncore's post is the one on acoustic impedance. Different materials have different impedances, and where there's a change you get some reflection.
So I think the OP's book is over-stating it when it says "ultrasound cannot travel through air right after it travelled through solid" (my bold). Actually, it's only difficult for sound to exit from the solid, but that does mean that very little energy travels into the air gap. The rest reflects, revealing the presence of the crack.
Likes nasu, russ_watters and pgirl1729
Topic about reference frames, center of rotation, postion of origin etc Comoving ref. frame is frame that is attached to moving object, does that mean, in that frame translation and rotation of object is zero, because origin and axes(x,y,z) are fixed to object? Is it same if you place origin of frame at object center of mass or at object tail? What type of comoving frame exist? What is lab frame? If we talk about center of rotation do we always need to specified from what frame we observe?
  • · Replies 31 ·
