How are phasors obtained from real values in AC?
  • Thread starter yosimba2000
  • Tags
    Ac Phasors
In summary, phasors are based on Euler's Formula, which states that ej*(X+phi) = cos(X+phi) + jsin(X+phi). This formula allows us to represent complex numbers, including imaginary numbers, in a simplified form. However, when dealing with real values like V(t) = Acos(V+phi), the phasor representation may not seem applicable since V(t) has no imaginary component. In this case, the phasor can be written as A<phi, where phi is the angle between the real and imaginary axis. This representation can be derived through various methods, such as graphically using a phasor diagram. Overall, understanding phasors and their applications can greatly aid
yosimba2000
206
Ok, so I know phasors are based on Euler's Formula: ej*(X+phi) = cos(X+phi) + jsin(X+phi)
But how do we use real value like V(t) = Acos(V+phi) in Euler's Formula?
V(t) has no imaginary component, so how can we write the phasor of this as A<phi, where phi is the angle between real and imaginary axis?
I guess what I'm really asking is the "derivation" of real values to another representation that uses imaginary numbers..
For a series circuit, you have to use current as the reference in the circuit, and then express the voltage across each component in degrees relative to that. For a parallel circuit the converse. It can be done graphically if preferred, using a phasor diagram, and this is a good way to understand what is going on.
FAQ: How are phasors obtained from real values in AC?
How do phasors represent AC signals?
Phasors are mathematical representations of AC signals that combine amplitude and phase information into a single complex number.
What is the relationship between phasors and real values in AC circuits?
Phasors are obtained from real values in AC circuits by converting the time-varying sinusoidal waveform into a constant amplitude phasor at a specific frequency.
How are phasors obtained from real values in AC using complex numbers?
Phasors are obtained by representing the real voltage and current values in an AC circuit as complex numbers and then performing vector addition or subtraction to determine the magnitude and phase angle of the resulting phasor.
Can phasors be used to simplify AC circuit analysis?
Yes, phasors can greatly simplify AC circuit analysis by allowing complex calculations involving sinusoids to be replaced with simpler algebraic operations on phasors.
What is the significance of the angle of a phasor in AC circuits?
The angle of a phasor represents the phase relationship between the voltage and current in an AC circuit. It is used to determine the power factor, which is a measure of how much of the apparent power is converted into useful work.
