- #36
DrChinese
- 1,921
PhysDrew said:Ah ok sorry Doc I missed that! I withdraw my post then. If I could get that reference off you, that would be greatly appreciated.
Thanks!
yuiop said:I am curious to know more about the first experiment. Are we talking about quantum erasure here? How are Bob's results erased?
I hadn't provided references previously because they are quite complicated, very difficult to discuss in the forum. So please read this very closely, and you may need to read it several times. It is easy to get lost in the mechanics and miss the fact that this is an ACTUAL experiment and has been accepted by the science community. It is fully in keeping with ordinary QM.
The "summary":
http://grad.physics.sunysb.edu/~amarch/
The actual experiment, in PDF:
http://grad.physics.sunysb.edu/~amarch/Walborn.pdf
Keep in mind that this experiment actually shows you both techniques in a single experiment if you will read it fully. Again, it is complicated. The point being, as I said in an earlier post, that the physical mechanism of a polarizer (or any other device by which you learn which-slit information) is NOT in and of itself responsible for causing the double slit pattern interference to disappear. If it were, then you could not have interference in the presence of 2 polarizers and you can - depending solely on their *relative* angle. And also, the pattern is can be dependent on the nature of a measurement on a remote particle. If you measure it such that which-slit information is obtained (or could be in principle) then there is no interference - even when they are sufficiently separated in space or time. In fact, the erasure can occur AFTER the pattern on a screen is created. (Please note that in such case - i.e. erasure - coincidence counting is required to discern the pattern.)
The loss of the DS interference is a consequence of the Heisenberg Uncertainty Principle, the physical mechanism for which is not understood. However, the mathematical mechanism is well understood and has been for over 80 years. The referenced experiment shows many interesting facets of QM in one paper. Good luck!
