How are the thermal expansion of a solid and the stress tensor related?
In summary, tensor stress is directly related to the internal pressure of a solid, and the stress is related to displacement or strain in the elastic range.
cito93
My idea is this: tensor stress is directly related to the internal pressure of a solid. That is to the force that the neighboring atoms exert each other in relation to a unit of surface.
When I heat a solid we can have the phenomenon of thermal expansion: this is connected to the fact that a deformation of the solid takes place which leads to an increase in the interatomic distances and therefore to a decrease in the frequencies of the phonons and a lowering of the energy of the system. For this deformation occurs. Now an increase in interatomic distances implies a decrease in internal pressure. The decrease in internal pressure is due only to the variation of the positions of the atoms in the crystal lattice with the expansion.
Given that the stress tensor is also calculated as a variation of the potential energy, it seems to me strongly linked to the internal pressure of the solid. In fact, even the potential energy depends only on the atomic positions in the lattice. I think this is the meaning of what is written in the article https://arxiv.org/pdf/2006.12867.pdf (equation (4)). Obviously, to find the correct parameters of the deformed cell I will have to apply an iterative procedure that leads me to equality between the internal pressure of the solid and the external one ("target pressure" -sentence extracted from the article-). This condition is necessary for the solid to be in equilibrium.
Also I don't understand why it is written that "The second term on the right-hand side of equation 4 corresponds to the partial derivative of the free energy with respect to volume in the quasiharmonic approximation".
From what I know the partial derivative of the free energy with respect to the volume at constant temperature is equal to the partial derivative of the kinetic energy with respect to the volume at constant entropy. This relation contains the Gruneisen parameters that allow me to describe the dependence of frequencies on volume and therefore on temperature, since in thermal expansion a change in volume corresponds to a change in temperature.
Why did the QSCAILD method "propose a way to include pressure from kinetic energy within this static pattern"? I understood that this sentence derives from the fact that the first term can be traced back to a kinetic term through the virial theorem while the second to the derivative of Helmoltz free energy with respect to volume in the quasi-harmonic approximation. Even this term if I am not mistaken is always equivalent to a kinetic term. So I wonder: maybe equation 4 in the article is just the expression for internal energy?
  • vanroekeghem2016.pdf
  • 2006.12867.pdf
Usually, stress is due to a mechanical load or force, and the load/force is distributed over a cross-sectional area, which is stress, and there can be tensile/compressive and shear forces involved. Depending on the stress level, deformation of a solid will occur (displacement of atoms from their positions prior to the load application). There is a relationship between the stress and displacement (or strain) in the elastic range for which the relationship between stress and strain are expressed by a set of equations with the elastic modulus and Poisson's ratio. See constitutive model.
https://en.wikipedia.org/wiki/Linear_elasticity
http://web.mit.edu/16.20/homepage/3_Constitutive/Constitutive_files/module_3_with_solutions.pdf
Note that for metals, the elastic modulus decreases with increasing temperature. There is also a shear modulus that also decreases with increasing temperature. Plastic (permanent) deformation and creep are more complicated.
With thermal expansion (with increasing temperature), no stress is produced, and displacement or thermal strain is expressed by a thermal expansion coefficient and a differential temperature.
In describing the deformation of a solid subject to load with increasing temperature, one has to account for the thermal expansion and deformation/strain appropriately.
Likes cito93
It is amorphous substances that can be described by 2 moduli alone - elastic modulus and either Poisson ratio or shear modulus.
Solids generally have 21 independent moduli connecting the 6 components of stress and 6 of strain.
True - thermal expansion of a homogenous solid should produce strain but no stress.
The "internal pressure" actually is connected to compressibility. How does elastic modulus change on thermal expansion?
Sounds like you were interested in the Grüneisen relation.
Related to How are the thermal expansion of a solid and the stress tensor related?
1. What is thermal expansion of a solid?
Thermal expansion of a solid refers to the increase in size or volume of a solid material when it is heated. This is due to the increase in kinetic energy of the particles within the material, causing them to vibrate and take up more space.
2. How is thermal expansion related to stress tensor?
The stress tensor is a mathematical representation of the internal forces and stresses within a solid material. Thermal expansion is related to the stress tensor because when a solid material expands due to heating, it experiences internal stresses that are captured by the stress tensor.
3. What is the relationship between thermal expansion and the stress tensor?
The relationship between thermal expansion and the stress tensor is that thermal expansion causes internal stresses within a solid material, which can be represented and quantified by the stress tensor.
4. How does the stress tensor affect thermal expansion?
The stress tensor affects thermal expansion by quantifying the internal stresses within a solid material that are caused by thermal expansion. These stresses can impact the overall expansion and deformation of the material.
5. Can the stress tensor be used to predict thermal expansion?
Yes, the stress tensor can be used to predict thermal expansion by analyzing the internal stresses within a solid material that are caused by thermal expansion. By understanding these stresses, we can better predict how a material will expand when heated.
  • Mechanical Engineering
  • Atomic and Condensed Matter
  • Other Physics Topics
