How calculate the Heat flux requiered to evaporate sub cool water
In summary, calculating the heat flux required to evaporate subcooled water involves determining the latent heat of vaporization and the difference in temperature between the water and its saturation temperature. This can be done using various equations, such as the Clausius-Clapeyron equation or the Antoine equation. The resulting heat flux can then be used to determine the necessary energy input for the water to reach its boiling point and evaporate.
Vincenzo
I was trying to validate a calculation I didusing ANSYS fluent, it's about a flow of water that enters a tube, the tube is 16m long and is being heated with a Heat Flux of q'=1077328,47 [W/m^2], now after the simulation runs and I check the results I find out that the steam quality at the exit of the tube is around 69% and not higher, and I need to get a higher quality steam, around 80%.
the mass flow is m'=0,5509 [kg/s]
the radius of the volume is R=0,01905 m
Length L=16m
Water enters at: T=20[°C]
velocity of entrance is: V=0,484 [m/s]
Pressure: P=2000 [psi] or 1,379e+7 [Pa]
Tast= 335,472°C
I have all the thermodinamics properties of the water at 20 °C, 180 °C, 320°C, 340°C and the saturated temperature 335,472°C
Now I ask because I know I'm getting the heat flux wrong but, as far as I knew, when studing Forced Internal Convection it is a good way to get into the problem using the properties at intermedium temperature to find the heat flow and heat flux, and that's why I used the propierties of water of 180°C, but, I know that the properties between 180°C and 320°C are way to different, the especific heat is almost 1,5 times higer and between 320°C and 335,472°C the specific heat increases more than 10%.
So, how can I get a more real approximation? Obviusly I can't go and use the Cp at 335.472°C and I need one Cp that allow me to find a representative Heat flow Q' to get a more representative heat flux. What other things I need to considerate? I know that Reynold's number grows too high when I choose a viscocity of higher temperature and it causes Nusselt's number grow, and in consecuence it increases the convection factor h.
Heat Flow: Q'=m'*Cp*ΔT
Q'=As*h*ΔT
Heat Flux: q'=h*ΔT
Reynold's number Re=V*D/μ
Nusselt's number (A big long eq that depends of Prandtl, Reynold and friction factor)
Nusselt's Number Nu= h*D/k
I was thinkg in doing tables on excel and repeat the calculations to differents lenghts (everything depending on lenght), the thing is, it's a long work, I will have to find many times the different properties of water and do some average to find the heat flux and I just need and approximation to find, validate and confirm the steam quality X=100%.
Thanks for the time!
Thank you for reaching out for help with your ANSYS Fluent simulation. It seems like you have a good understanding of the equations and factors involved in your problem, and I can see that you have put a lot of effort into finding a solution. However, as you mentioned, the properties of water can vary significantly at different temperatures and it can be difficult to find a single representative value for your heat flux.
One approach you could take is to use a more advanced simulation software that allows for more accurate modeling of the fluid properties, such as COMSOL or OpenFOAM. These software packages have built-in thermodynamic tables and can also incorporate user-defined equations for properties like specific heat. This may give you more accurate results and help you achieve the desired steam quality.
Another option is to perform sensitivity analyses, where you vary one parameter at a time and see how it affects the results. This can help you identify which factors have the most significant impact on your heat flux and steam quality, and allow you to focus your efforts on those areas.
Lastly, I would recommend consulting with a specialist in the field of fluid dynamics or heat transfer, who may be able to provide valuable insights and suggestions for your specific problem. Good luck with your simulation and I hope you are able to achieve your desired results.
Related to How calculate the Heat flux requiered to evaporate sub cool water
1. What is the equation for calculating heat flux for evaporating subcooled water?
The equation for calculating heat flux for evaporating subcooled water is: Q = m * (h_fg + c_p * (T_w - T_sat)) / t_e, where Q is the heat flux in watts, m is the mass flow rate in kg/s, h_fg is the latent heat of vaporization in J/kg, c_p is the specific heat capacity of water in J/kgK, T_w is the water temperature in Kelvin, T_sat is the saturation temperature in Kelvin, and t_e is the evaporation time in seconds.
2. What is subcooling and how does it affect the calculation of heat flux?
Subcooling refers to the temperature difference between the water temperature and its saturation temperature. It affects the calculation of heat flux by increasing the required heat flux to evaporate the water due to the additional energy needed to overcome the subcooling effect.
3. How does the heat flux required to evaporate subcooled water change with different water flow rates?
The heat flux required to evaporate subcooled water is directly proportional to the water flow rate. This means that as the water flow rate increases, the heat flux required to evaporate the water also increases.
4. What factors can affect the heat flux required to evaporate subcooled water?
Some factors that can affect the heat flux required to evaporate subcooled water include the initial temperature of the water, the saturation temperature, the flow rate of the water, and the surface area of the water in contact with the heating source.
5. Can the heat flux required to evaporate subcooled water be calculated for any type of heating source?
Yes, the heat flux required to evaporate subcooled water can be calculated for any type of heating source as long as the necessary parameters are known, such as the specific heat capacity of water, the latent heat of vaporization, and the initial and saturation temperatures of the water.
  • Mechanical Engineering
  • Thermodynamics
