How can a mixed state particle absorb a "quanta" of energy?
In summary, the conversation discusses the concept of a two-state system, specifically a single nucleus that can be aligned or anti-aligned with an external magnetic field. The question is raised about how the nucleus can absorb energy in quanta, despite being in a "mixed state" where its wavefunction is 50% up and 50% down. The expert clarifies that this state is actually a superposition and explains the mathematical equations for the state before and after the interaction. The expert also notes that the state after the interaction is still in a superposition, despite the nucleus being entirely in the up state. The case of a true mixed state is also briefly mentioned.
ForgetfulPhysicist
31
Imagine a two-state system, e.g., a single nucleus that can be aligned or anti-aligned with an external magnetic field. If that nucleus is in a "mixed state" at time zero, such that it's wavefunction is 50% up and 50% down at time zero, why can that nucleus absorb a "quanta" of radiofrequency electromagnetic energy equal to the energy gap between the "down state" and the "up state". It seems to violate conservation of energy, because the system at time zero had more energy than the "down state" , and the absorbed photon had energy equal to the difference between the down state and the up state, and after absorption I assume the wavefunction is entirely in the up state? Somebody please help.
Damon Turney said:
If that nucleus is in a "mixed state" at time zero, such that it's wavefunction is 50% up and 50% down at time zero...
You said "mixed state", but what you're describing sounds like a superposition not a mixture. Could you clarify which you're asking about?
I'm guessing both, but anyway I'd like to hear your answer for both cases. In NMR textbooks (e.g. Schlicter), as far as I understand it, a randomly chosen nuclei is typically in both a mixed state AND a superposition of states. For example, a randomly chosen nuclei, which is located in a magnetic field that points upward along the z-direction, might have a spin_z component that is "mixed" between the up and down direction such that it's magnetic moment vector is perpendicular to z-direction, but the spin_x and spin_y components deterministically rotate coherently around the z-axis.
My question was motivated by this NMR example. Basically, I'm confused as to how the nuclei can only absorb energy in quanta (energy of up state - energy of down state) yet the nuclei are usually NOT in the down state.
Let me first assume that by "mixed" state you mean superposition. Let me denote the down and up state by ##|0\rangle## and ##|1\rangle##, respectively, and the quantum of EM energy by ##|1_{\rm EM}\rangle##. Before the interaction the full state is
$$ \frac{1}{\sqrt{2}}|0\rangle|1_{\rm EM}\rangle + \frac{1}{\sqrt{2}} |1\rangle|1_{\rm EM}\rangle $$
while after the interaction it becomes
$$ \frac{1}{\sqrt{2}}|1\rangle|0_{\rm EM}\rangle + \frac{1}{\sqrt{2}} |1\rangle|1_{\rm EM}\rangle $$
where ##|0_{\rm EM}\rangle## is the EM vacuum. You can easily check that average energy before the interaction is the same as average energy after the interaction. Note, however, that the state after the interaction is in a superposition. Even though the nucleus is entirely in the ##|1\rangle## state, the EM state is neither entirely ##|0_{\rm EM}\rangle## nor entirely ##|1_{\rm EM}\rangle##. In your analysis you tacitly assumed that the EM quantum is entirely absorbed after the interaction (i.e. that its state after the interaction is entirely ##|0_{\rm EM}\rangle##), but that assumption was wrong.
The case when "mixed" really means mixed is almost the same. Loosely speaking, the only important difference is that instead of ##+## in the equations above you have to put a logical or.
Likes Lord Jestocost, bhobba, ForgetfulPhysicist and 2 others
Your answer is very illuminating (no pun intended)! Thank you!
Likes Demystifier
Demystifier, after researching this issue a couple weeks, I have one final question. So it seems that the NMR process is similar to your answer. But I'm confused. The incoming photon in NMR is carefully selected to have "resonant frequency" with the nuclei spin precession, meaning it has exactly enough energy to INSTANTLY flip the nuclei spin from anti-parallel to parallel with the magnetic field, but the NMR textbooks all say that the incoming photons rotate the nuclei spins monotonously and smoothly in time (i.e., they do not TOTALLY flip a nuclei spin instantly), which makes me think that a given photon leaves the collision in a superposition or mixed state like in your answer. So the photons would all leave the collision in a mixed state and would only transfer a little bit of energy? It's confusing because the photon perspective suggests the transfer of energy occurs in increments (quanta) and could TOTALLY flip a nuclei, but the typical NMR textbook (like Slichter) makes it sound like energy transfer from the photons is smoothly monotonously and each photon-nuclei collision only rotates the nuclei a small amount. Which is it? And can you recommend a textbook that explains this?
I'm not an expert in NMR, so I don't know the details. However, it is possible that a nucleus absorbs photon of energy E and soon later emits another photon with energy E'<E. This is a two-step process which effectively looks as if the nucleus absorbed only a part of the photon's energy. Perhaps something like that happens in NMR.
Damon Turney said:
INSTANTLY flip [...] rotate the nuclei spins monotonously and smoothly in time
These are two different ways of modeling the same situation. It is like with switching on the light in your home. Generally you think of it as being instantaneous but when paying careful attention you know of course that it happens (on a finer time scale) in a continuous way.
In the quantum case you can model an absorption process as a quantum jump process (instantaneous jumps) or as a quantum diffusion process (continuous jumps). A useful related paper is ''Interpretation of quantum jump and diffusion processes illustrated on the Bloch sphere'' by Wiseman and Milburn.
Note that both quantum jump and quantum diffusion processes are dissipative, not unitary. In unitary quantum physics, there are neither jumps nor definite absorption.
Likes vanhees71, ForgetfulPhysicist and Mentz114
Thank you very much -- that PRA paper is outstanding.
Related to How can a mixed state particle absorb a "quanta" of energy?
1. How does a mixed state particle absorb a "quanta" of energy?
A mixed state particle can absorb a "quanta" of energy through a process called excitation. This is when the particle's energy level increases due to the absorption of the "quanta" of energy.
2. How does the "quanta" of energy interact with the mixed state particle?
The "quanta" of energy interacts with the mixed state particle through the electromagnetic force. This force allows the particle to absorb the "quanta" of energy and increase its energy level.
3. Can any type of mixed state particle absorb a "quanta" of energy?
Yes, any type of mixed state particle can absorb a "quanta" of energy as long as it has an energy level that matches the energy of the "quanta".
4. What happens after a mixed state particle absorbs a "quanta" of energy?
After absorbing a "quanta" of energy, the mixed state particle may undergo a change in its physical properties. It may also release the absorbed energy through emission, or it may transfer the energy to other particles through various processes.
5. Is the process of a mixed state particle absorbing a "quanta" of energy instantaneous?
No, the process of a mixed state particle absorbing a "quanta" of energy is not instantaneous. It takes time for the particle to interact with the "quanta" of energy and undergo excitation. The speed of this process depends on various factors such as the type of particle and the energy of the "quanta".
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
