MHB How Can Absolute Value Definitions Be Used to Rewrite Expressions?
  • Thread starter Thread starter mathdad
    Absolute
The absolute value definition states that |x| equals x for non-negative x and -x for negative x. This can be applied to rewrite expressions lacking absolute values. For example, the expression |x^4 + 1| can be simplified, as x^4 + 1 is always greater than zero. Therefore, |x^4 + 1| equals x^4 + 1 for all real numbers x. This confirms that the expression remains unchanged when applying the absolute value definition in this case.
mathdad
The definition of absolute value states the following:
| x | = x when x is > or = 0
| x | = -x when x < 0
I can use the above definition to rewrite expressions that do not contain absolute values.
| x^4 + 1 |
Since x^4 + 1 > 0, then the answer is simply the expression itself or x^4 + 1.
Correct?
Mathematics news on Phys.org
Yes, for all real numbers, x, |x^4+ 1|= x^4+ 1.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
