- 2,130
- 2,706
I don't know whether this question is suited to this forum specifically, but since it deals with electronics, I am putting it here.
We have an old air-conditioner, bought in 2007. As you can understand, it is one of the old models running on R22 gas and it switches off the compressor when the proper room temperature is reached (rather than varying the compressor speed).
In our region, voltage fluctuations are major problems for our appliances. So, all costly appliances have to be protected with a voltage stabilizer. The AC also has one.
Recently, this stabilizer started malfunctioning. The relay is electromechanical, and it often gets stuck on one side, resulting in either a very high voltage or a very low voltage.
Yesterday, I removed the stabilizer. And all of a sudden, the AC started working brilliantly. For the last few months, it was not cooling properly, something that indicated gas leak or low gas pressure. But all tests were fine, so we were thinking about changing it. But when I removed the stabilizer, the AC started cooling in a much better way. It seemed we were back in 2007 or so.
In India, the rms AC is around 220V to 230V, which dips to around 200V at night and sometimes surges all of a sudden to 250V. During the last world cup, we have experienced voltages as low as 140V. That is why we had to install the stabilizers.
The work of a stabilizer is to maintain the potential difference. If it gives a proper voltage output (in the range of about 210V to 230V), how can it affect the performance of the AC? Is it just coincidence, or is there science behind this?
