How can angular momentum be quantized?
In summary: I'm not sure if it's significant. I'm just trying to be helpful.In summary, the angular momentum of a particle is quantized with respect to an origin, right? Well, what's stopping me from changing my origin ever so slightly, so that the angular momentum changes ever so slightly?How would you measure it?Nothing is stopping you from doing that.
dEdt
288
Angular momentum is defined with respect to a certain origin, right? Well, what's stopping me from changing my origin ever so slightly, so that the angular momentum changes ever so slightly?
Nothing is stopping you from doing that. For example, the ground state of the hydrogen atom has its electron in a state of zero orbital angular momentum, if you use the proton as the origin. If you choose an infinitesimally different origin, this will be a mixture of all orbital angular momenta 0, 1, 2, ... The average will shift infinitesimally.
When we say that intrinsic spin has a specific value for a specific type of particle, I guess we mean with the particle itself chosen as an origin. This becomes a little subtle in the case of a massless particle, which doesn't have a rest frame.
I thought "quantized angular momentum" meant that when we try to measure angular momentum, we see it in particular sized lumps.
If we measure angular momentum in one orientation, subsequent measurements get the same thing - but if we rotate the axis we measure against, the new statistics will come from a mixture of different angular momentum states ... so the expectation (= average) can change continuously ... but a subsequent measurement still gets the same lumps doesn't it?
We're not talking about a rotation, the question posed was, what happens to L under a translation? And I agree with what both you and Ben have said: the result will be a superposition of L values, the same discrete integer values, but the expectation will change slightly.
Quantitatively the coefficients in this superposition can be obtained from the commutator [L2, p]. Another way is to use a representation: consider the harmonic functions F(r) = rP(cos θ). These are solutions of Laplace's equation, each having a definite value of L = ℓ. Consider them as the basis in a function space.
An infinitesimal translation along the z-axis corresponds to applying a derivative, ∂/∂z. For example for ℓ = 2, F2 = ½(3z2 - r2), and ∂F2/∂z = 2z = 2F1. Similarly for each value of ℓ, ∂F/∂z can be written as a linear combination of F's with L < ℓ. Thus the result of an infinitesimal translation on a state of angular momentum L = ℓ will be that linear superposition of states with angular momentum L < ℓ.
Oh fair enough ... though if I measure angular momentum, then use identical apparatus in a different position (i.e. translated, but not rotated) on the same particles, doesn't that just give the same measurement? In fact, would we normally expect a mere translation of axis to change the projections of a vector? Wouldn't a rotation, instead, be more illustrative for OPs question? Or maybe I have the wrong question?
I thought the question was: "How can angular momentum be quantized?" ... which I happily interpreted as "What do we mean by 'angular momentum is quantized'?" ... which, admittedly, may not have been the interpretation intended. OP provided an example of how he may expect to change angular momentum... particularly in terms of how L is defined in relation to axes.
The z-axis projection of a "regular" vector depends on how we've drawn the axes after all.
I understood that the different axis were defined (in a meaningful way) by the measuring apparatus.
eg. The Stern-Gerlach apparatus has an important axis, which gets called "z" a lot. The angular momentum is quantized with respect to this axis, no matter how the apparatus is oriented in space. You can put random x-y position particles (the beam) in with random orientation of spins and still get quantized results out.
I was guessing that this was the sort of thing OP was asking about.
So it seems reasonable to say that the angular momentum is said to be quantized because that is what we get when we measure it. It gets that way (the "how" part), regardless of orientation, because of the interaction with the measuring apparatus. We can (very accurately) account for this in the mathematics by considering superpositions of orthogonal angular momenta.
In a way, what OP seems to be wrestling with is a less obvious manifestation of "wave particle duality" ... the math is continuous but the resulting measurement is discrete. OR I have been overthinking this and looked for deep meaning where there is none ;)
I like to think about quantization as arising from boundry conditions. In this case, it's a spherical boundry condition that says that the allowed orbits must be such that the wavefunction of the electron "overlaps with itself" when traced around the nucleus. If it's not, then it will destructively interfere with itself and will not form a stable orbit.
I'm also not sure what you gain from "changing origin", you would just be changing the theoretical description of the states, not changing the states themselves. It would be harder to see the quantization because you're using a non-intuitive basis, but it wouldn't remove the actual quantization in any way.
FAQ: How can angular momentum be quantized?
1. What is angular momentum and why is it quantized?
Angular momentum is a physical quantity that measures the rotational motion of an object around an axis. It is quantized because it can only exist in certain discrete values, as observed in experiments, rather than being able to take on any value like other continuous quantities.
2. How is angular momentum quantized?
Angular momentum is quantized due to the properties of the quantum mechanical system. In quantum mechanics, angular momentum is represented by operators that have discrete eigenvalues, meaning that angular momentum can only take on certain values rather than being continuous.
3. What is the relationship between angular momentum and quantum numbers?
The quantization of angular momentum can be described by quantum numbers, which are labels used to identify the different energy states of a quantum system. The values of the quantum numbers determine the allowed values of angular momentum for a given system.
4. Can the quantization of angular momentum be explained by classical mechanics?
No, the quantization of angular momentum is a phenomenon that can only be explained by quantum mechanics. In classical mechanics, angular momentum can take on any value, whereas in quantum mechanics it is quantized and can only exist in certain discrete values.
5. How does the quantization of angular momentum affect the behavior of particles?
The quantization of angular momentum can have a significant impact on the behavior of particles, especially at the microscopic level. It can dictate the allowed energy levels and transitions of particles, as well as the stability of atoms and molecules. It also plays a crucial role in explaining the properties of subatomic particles such as electrons and protons.
