How can contour integration be used to solve this week's problem?
  • MHB
  • Thread starter Chris L T521
In summary, contour integration is a technique used in complex analysis to evaluate integrals along a specific path in the complex plane. It can be used to solve difficult integrals and saves time and effort compared to traditional methods. However, it is only applicable to certain types of problems and requires a good understanding of complex numbers.
Chris L T521
MHB
915
Here's this week's problem.
Problem: Use contour integration to show that
\[\int_{-\infty}^{\infty}\frac{e^{-2\pi i x\xi}}{(1+x^2)^2}\,dx = \frac{\pi}{2}(1+2\pi|\xi|)e^{-2\pi|\xi|} \]
for all $\xi$ real.
Hint:
WLOG, suppose that $\xi\geq 0$ (this way, you don't have to worry about the absolute values for the time being). Then consider using the lower half circle as the contour for this integral.
No one answered this week's question. Here's my solution below.
WLOG, suppose that $\xi\geq 0$ (so we don't have to worry about absolute values for the time being). Let the closed contour $\Gamma$ be the lower half circle. Let $f(z)=\frac{e^{-2\pi i z\xi}}{(1+z^2)^2}$. Clearly, $f(z)$ has two poles of order $2$ at $z=i$ and $z=-i$. Based on how we defined $\Gamma$, $z=i$ is not contained within the closed contour, so we need to find the residue at $z=-i$. We see that\[\begin{aligned}\text{res}_{-i}f(z) &= \lim_{z\to-i}\frac{\,d}{\,dz}\left[\frac{e^{-2\pi i z\xi}}{(z-i)^2}\right]\\ &=\lim_{z\to-i}\frac{-2\pi i \xi(z-i)^2e^{-2\pi i z\xi}-2(z-i)e^{-2\pi iz\xi}}{(z-i)^4}\\ &=-i\frac{(1+2\pi\xi)e^{-2\pi\xi}}{4}\end{aligned}\]
Therefore, by the residue theorem, we see that
\[\int_{\Gamma}\frac{e^{-2\pi iz\xi}}{(1+z^2)^2} = \int_{-R}^{R}\frac{e^{-2\pi i x\xi}}{(1+x^2)^2}+\int_{C_R}\frac{e^{-2\pi iz\xi}}{(1+z^2)^2} = \frac{\pi}{2}(1+2\pi\xi)e^{-2\pi\xi}\]
Observe that $e^{-2\pi iz\xi}\leq 1$ for $\text{Im}z\leq 0$ and $\xi\geq 0$. Thus, as $R\rightarrow\infty$,
\[\left|\int_{C_R}\frac{e^{-2\pi iz\xi}}{(1+z^2)^2}\,dz\right|\leq \frac{\pi R}{(R^2+1)^2}\]
which goes to zero. Therefore, as $R\rightarrow\infty$, we have
\[\int_{-\infty}^{\infty}\frac{e^{-2\pi ix\xi}}{(1+x^2)^2}\,dx=\frac{\pi}{2}(1+2\pi|\xi|)e^{-2\pi|xi|}\]
and the proof is complete.
(PS: I just finished posting a solution to POTW 42, so feel free to check that out too!)
FAQ: How can contour integration be used to solve this week's problem?
What is contour integration?
Contour integration is a technique used in complex analysis to evaluate integrals along a specific path or contour in the complex plane.
How can it be used to solve problems?
Contour integration can be used to evaluate integrals that are difficult or impossible to solve using traditional methods. It allows for the use of complex numbers to simplify the integration process.
Can contour integration be used in any problem?
No, contour integration is typically used in problems involving complex functions and integrals. It may not be applicable to all types of problems.
What are some benefits of using contour integration?
Contour integration can save time and effort in solving difficult integrals, and it can also provide more accurate results compared to other methods. It also allows for the use of complex numbers, which can be useful in certain applications.
Are there any limitations or challenges when using contour integration?
One limitation is that contour integration can only be used for functions that are analytic (have a continuous derivative) within the region of the contour. It also requires a good understanding of complex numbers and techniques for manipulating them.
