How can dimensional analysis be carried out correctly?
In summary, Walter Lewin discussed how dimensional analysis can be used to determine the physical quantities related to a ball's fall. After discussing the case of a falling ball, he mentioned that dimensional analysis can also be used to determine constants that are not related to mass. He also mentioned that dimensional analysis can be helpful in many ways, but is not limited to physical constants.
PhysExplorer
Hello!
May I first please direct your attention to Walter Lewin's first Classical Mechanics lecture on Units, Dimensions and Scaling Arguments?
He first carried out a dimensional analysis to determine the relation between the time taken for a ball to fall from a particular height to the height itself, the mass of the ball and gravitational acceleration.
He then mentioned that the dimensional analysis could just as well have been carried out another way, leading to different results.
May anyone please tell me how in this case (and in general) how one can correctly determine all the physical quantities related to the time taken for the ball to fall?
Thank you very much in advance.
From my point of view, there's not such a way. Dimensional analysis just provide you from possible answers to a problem in what dimensions regards.
In the case of the falling ball, you could take into account other variables as the air drag or the distance to the Sun, for example. But, as many times in physics, you idealize the problem. So in this particular case, you suppose that there is no air drag and no other phenomena affecting the fall. What I mean is that your idealized ball is completely described by it's mass, it's height and gravitational acceleration on the Earth' surface.
You could idealize the problem in a different way to take into account other things such air drag, but in that case you should try a different approach also.
Just my point of view.
I have some problems about this analysis. First, we consider the quantities that may related our problem and then this analysis tells us what that relation is. But we have a dimensionless multiple also. And here is my question, we know, dimensionless multiple does not mean an independent constant multiple. It may change with respect to any quantities that we concern. Maybe it is (mass1+mass2)/( mass1-mass2). If this is possible how this analysis be useful?
One more thing, this problem appears in not only the dim.less multiple. Assume that we found that the power of the mass must be one. But if we have two different masses, how can I know wheter it is "product over sum" or "squared product over cube of sum" or what else??
As soon as you have two quantities with the same units, dimensional analysis can be tricky to impossible for those quantities. Sometimes you can find the dependence on those quantities in other ways, like reducing the two-body Kepler problem to a one-body problem with the reduced mass, and applying dimensional analysis to this problem with a single mass.
Considering the symmetricity of two quantities with same units may also be useful. I mean let's say on masses f(m1,m2)=f(m2,m1) must be hold because we choose m1 and m2 arbitrarily. This eliminates much of the possibilities but not all. We cannot write for example (2m1+m2). We must construct our expression from symmetrical terms. But thank you for the reduction idea, it is new to me.
Dimensional analysis is useful in many ways. But I think you are trying to take it too far. What about a law in which an unknown constant has dimensions?
My point is, dimensional analysis is helpful and necessary always. But don't try to take it too far.
I mean, division of two masses is dimensionless but not constant. It depends on the masses.
You can have constants like the speed of light, sure, but you can include those in the analysis.
PhysExplorer said:
Hello!
I'm not an expert but as per my knowledge,dimensional analysis deals with the fundamental physical quantities. So you should first guess the relevant physical quantities for the given situation and break them into fundamental quantities. That's what I remember from my physics class 3 years ago. For example, to calculate the time period of a pendulum, you should assume relevant physical quantities. If I assume it depends on mass, length of pendulum and gravitational acceleration, it would be sufficient. So, I can write
T=kmalbgc...(1)
[M]0L0T1=k[M]a[L]b[LT-2]c
From the indices' arithmetic, I get a=0, b=1/2,c=-1/2.
Substituting a,b,c in (1), you'll get the relation as
T=k√l/√g..
Related to How can dimensional analysis be carried out correctly?
1. What is dimensional analysis?
Dimensional analysis is a mathematical tool used in science to convert units from one system to another or to check the consistency of equations by examining the dimensions of each term.
2. What are the steps involved in dimensional analysis?
The first step is to identify the physical quantities involved in the problem and their corresponding units. Then, express each unit in terms of fundamental units (such as length, mass, and time). Next, write out the equation or relationship between the quantities in terms of their units. Finally, cancel out the units that are the same on both sides of the equation to determine the units of the final answer.
3. How can dimensional analysis help in problem-solving?
Dimensional analysis can help in problem-solving by providing a systematic approach to converting units and checking the consistency of equations. It also allows for quick and easy conversions between different unit systems, which can be especially useful in scientific experiments and calculations.
4. What are the common mistakes to avoid in dimensional analysis?
Some common mistakes in dimensional analysis include using incorrect or inconsistent units, forgetting to convert units to their fundamental form, and not properly canceling out units on both sides of the equation. It is also important to pay attention to the direction of the conversion (multiplication or division) and to the significant figures in the final answer.
5. How can one practice and improve their dimensional analysis skills?
One can practice and improve their dimensional analysis skills by working on practice problems and exercises, both independently and with the guidance of a teacher or tutor. It is also helpful to review the basic principles and rules of dimensional analysis and to check the units in all equations and calculations. With practice, dimensional analysis can become a valuable tool for accurate and efficient problem-solving in science.
  • Classical Physics
  • Other Physics Topics
  • Mechanics
