How can ΔJ = 0 for an electric dipole transition?
In summary: So in summary, when considering multi-electron atoms, the selection rule for electric dipole transitions is that ΔJ=0,±1. This is because the total angular momentum change is not necessarily equal to the single electron transition change, as the other electrons can rearrange themselves to compensate for the change in angular momentum. This is why transitions like 4s->3s are not possible, as they have a ΔL=0 which is forbidden for an electric dipole transition. Additionally, the angular momentum of the photon can contribute to a reorientation of the relative orientation of L and S, allowing for transitions like 2S1/2->2P1/2 which have a ΔL=1 but a ΔJ=0
lawlieto
Consider a multi-electron atom. (In our course we deal with alkalis mostly so that we have energy levels which are similar to the hydrogenic ones with quantum defect. I don't know if that is relevant here)
Edit: l = orbital angular momentum of a single electron, L = total orbital angular momentum of the electrons, J = L+S with S = total spin
For an electric dipole transition in hydrogen Δl = ±1. Since we only consider one electron jumping at a time in multi electron atoms, for that single electron it's still true that Δl = ±1. However, one of the selection rules for multi electron atoms is that ΔJ=0,±1. Since ΔS=0, ΔL=0,±1. (if L=0 initially, then the 0 change is not possible). How is it possible for total angular momentum change to be 0 though? If only one electron transitions at a time and one photon is emitted, that photon carries away ±1 unit of angular momentum, but if the overall angular momentum change of the atom is 0, how is angular momentum conserved?
For instance, if an electron jumps from 4s->3p there is already +1 change in ΔL. This single electron cannot go 4s->3s so that ΔL=0, since that is forbidden for an electric dipole transition. So for a e.g. 4s->3p transition, do the other electrons rearrange themselves somehow? I was thinking the other electrons must have some role in this, as this 0 change in L is not possible for a single electron atom.
J is not necessarily L + S. J can take values L + S, L + S - 1, ... L - S (as far as those values are positive). Thus ΔJ = 0 does not imply that ΔL = 0.
A single electron is 4s gives a term 2S1/2. In 3p, it gives 2P1/2 and 2P3/2, both of which are accessible from 2S1/2. The transition 2S1/22P1/2 has ΔS = 0 and ΔJ = 0, but ΔL = 1.
Likes lawlieto
To complete @mjc123 good answer, the angular momentum of the photon "goes into" a reorientation of the relative orientation of L and S. This is why L = 0 ↔ L = 0 and J = 0 ↔ J = 0 transitions are forbidden: if L = 0 or J = 0, then there is no relative orientation to begin with, so the angular moment of the photon must go into changing L or J.
Likes lawlieto
That makes a lot of sense! Thank you.
Thanks for the clarification!
Related to How can ΔJ = 0 for an electric dipole transition?
1. What is an electric dipole transition?
An electric dipole transition is a change in the energy state of an atom or molecule due to the absorption or emission of a photon. This results in a change in the dipole moment of the system.
2. Why is ΔJ = 0 for an electric dipole transition?
ΔJ represents the change in the total angular momentum of the system. For an electric dipole transition, the photon carries one unit of angular momentum, so the change in the system's angular momentum must also be one unit. Since J can only change by integer values, ΔJ must be equal to 0.
3. How does ΔJ = 0 affect the selection rules for electric dipole transitions?
The selection rules for electric dipole transitions state that the change in the electronic quantum number must be ΔJ = 0, ±1. Since ΔJ = 0 is always satisfied for electric dipole transitions, this means that transitions with ΔJ = ±1 are allowed, while transitions with ΔJ = 0 are forbidden.
4. Can ΔJ = 0 ever occur in other types of transitions?
No, ΔJ = 0 is specific to electric dipole transitions. Other types of transitions, such as magnetic dipole or electric quadrupole transitions, have different selection rules and can have non-zero values for ΔJ.
5. How does ΔJ = 0 affect the polarization of the emitted or absorbed light in an electric dipole transition?
Since ΔJ = 0 means that the change in the system's angular momentum is in the same direction as the photon's angular momentum, the emitted or absorbed light will be linearly polarized in the same direction as the transition's dipole moment.
  • Atomic and Condensed Matter
  • Quantum Physics
