kikifast4u
- 10
Two discs, each of mass m are connected by a stiff spring. Can you press the top disc down so far that when released it will spring back and lift the bottom disc off the table? Discuss the application of energy conservation to this problem.
2. The attempt at a solution
Well, I'm really stuck at this one and I really don't know how to do it.
I thought about using energy. When you push the spring, you get potential energy, maximum (k*h^2)/2, where h is the distance between the two discs. When you release the top disc, some of the potential energy is converted into gravitational potential and some into kinetic. I am able to find the velocity of the first disc when it comes back to its original position, but that doesn't help.
Since it's a stiff string, it won't extend when the first mass will go beyond it's original point (if it does), isn't it?
The hint I am given is "How big must the tension in the spring be if the lower plate is about to ‘lift off’?" I know the tension must be bigger than the weight of the second disc.
So I should find what the tention is. How do I do that?
