- #36
Juan R.
- 416
- 1
arivero said:Hmm Connes uses (implicitly) the concept of convergence, as topology relies on it. And yes, convergence uses the concept of infinite sequences, but you can recast it in the infamous epsilon/delta format, enough for operative purposes. The concept of infinitesimal as used in calculus is a bit more sophisticated that the concept of limit, the subtle points about differential calculus come because it involves the simultaneous use of various infinite/infinitesimal quantities. Eg [tex]\delta x \over \delta t[/tex] or [tex]\sum^\infty_i \delta x_i[/tex].
It is very hard to get rid of the concept of convergence. You lose a lot of math, for instance the numbers pi and e. But you can admit convergence and still be suspicius about simultaneus use of infinit* entites; in this sense it is very welcome that quantum mechanics is against a one of these simultanities: position and momentum. Remember also that primitive quantum mechanics was formulated as an index theorem (the bohr/sommerfeld formulation) so it is very interesting that Connes abstraction drives also to this kind of theorems.
No problem with concept of convergence for series n but Connes takes the eigenvalue of the infinitesimal explicitly from n --> infinite on the operator.
Note that he does n --> infinite, cannot do n = infinite. Precisely, this indicates the same inconsistency that classical definition using limits.
