How can I calculate this hyperbola's equation?
In summary, the conversation discusses the process of calculating the equation of a hyperbola with a "sphere radius" of 153mm and a "hyperbolic factor" of 21500. The individual is using a program called optical ray tracer for modeling light rays in 2D and is designing a telescope's mirror. They express difficulty in finding information online about these parameters and are seeking guidance.
liamnerf
Hello. I am currently trying to calculate the equation of a hyperbola, which I have little experience with. The hyperbola has a "sphere radius" of 153mm and a "hyperbolic factor" of 21500. I haven't been able to find anything online about what these mean and am lost. The parameters where given to me by a program called optical ray tracer which is used to model light rays in 2D. I am currently designing a telescope's mirror.
Mathematics news on Phys.org
Hello liamnerf
Welcome to PF!
This may be of help.
Likes liamnerf
The Wikipedia page could also be of help.
Likes liamnerf
Related to How can I calculate this hyperbola's equation?
1. How do I find the center of a hyperbola?
To find the center of a hyperbola, you will need to know the coordinates of the vertices and the foci. The center of a hyperbola is located at the midpoint between the two vertices.
2. What is the standard form of a hyperbola's equation?
The standard form of a hyperbola's equation is (x-h)^2/a^2 - (y-k)^2/b^2 = 1, where (h,k) is the center of the hyperbola and a and b are the distances from the center to the vertices and foci respectively.
3. How do I calculate the eccentricity of a hyperbola?
The eccentricity of a hyperbola can be calculated using the formula e = c/a, where c is the distance from the center to the focus and a is the distance from the center to the vertex. The eccentricity of a hyperbola is always greater than 1.
4. Can I find the equation of a hyperbola if I only have one point on the curve?
No, you will need at least two points on the curve to determine the equation of a hyperbola. This is because a hyperbola has two branches and one point alone cannot determine the shape of the entire curve.
5. What is the difference between a horizontal and a vertical hyperbola?
A horizontal hyperbola has its transverse axis (the line connecting the two vertices) running horizontally, while a vertical hyperbola has its transverse axis running vertically. This difference affects the values of a and b in the standard form of the equation, but does not change the overall shape of the hyperbola.
  • STEM Academic Advising
  • Other Physics Topics
