How can I define what is the wavefunction
In summary, the wavefunction can be defined as a linear combination of eigenvectors with corresponding energies. The constants can be determined by using the eigenvalues and eigenvectors to construct an invertible matrix and a diagonal matrix. This approach is also applicable in quantum physics. The uniqueness of the constants can be easily proved by normalizing the eigenvectors and using the sum formula for the wavefunction.
Mancho
How can I define what is the wavefunction if I'm given eigenvectors V1, V2,...Vn and energies E1, E2,. ..En.
I know that it must be a linear combination but how about constants?
I'm not expert in physics but in Linear Algebra, If we know the eigenvalues (energies here) and corresponding eigenvectors, we can construct the invertible matrix P, having those eigenvectors as columns, and the diagonal matrix D, having the corresponding eigenvalues on the diagonal then the matrix (operator) itself is given by
[tex]A= PDP^{-1}[/tex].
I'm sure there is something similar for quantum physics.
If the eigenvectors pertain to a compact selfadjoint operator, then any Hilbert space vector in which the operator acts can be chosen as a valid <wavefunction>. As for the uniqueness of the constants, well, it's very easy to prove, because the eigenvectors are perpendicular one to another and can be normalized to modulus 1, so that from (the sum in RHS converges weakly to the vector in the LHS)
[tex] \Psi = \sum_k a_k \psi_k [/tex]
it follows that, for example,
[tex] a_3 = \langle \psi_3, \Psi\rangle [/tex]
FAQ: How can I define what is the wavefunction
What is the wavefunction?
The wavefunction, also known as the wave equation or quantum state, is a mathematical description of the quantum state of a particle or system in quantum mechanics. It is used to predict the probability of finding a particle in a particular location or state at a given time.
How is the wavefunction defined?
The wavefunction is defined as a complex-valued function of space and time that satisfies the Schrödinger equation. It is often denoted by the Greek letter psi (ψ) and can be written as a function of position (x) and time (t) or momentum (p).
What does the wavefunction represent?
The wavefunction represents the quantum state of a particle or system, including its position, momentum, and energy. It is a fundamental concept in quantum mechanics and is used to calculate the probability of observing different states of a system.
How does the wavefunction relate to probability?
The wavefunction is related to probability through the Born rule, which states that the probability of finding a particle in a specific state is equal to the square of the absolute value of its wavefunction at that point. In other words, the wavefunction describes the probability of finding a particle in a particular location or state.
Can the wavefunction be observed or measured?
No, the wavefunction itself cannot be directly observed or measured. It is a mathematical construct used to describe the quantum state of a particle or system. However, its effects can be observed through experiments and calculations that use the wavefunction to predict the behavior of quantum systems.
