MHB How Can I Determine the Values of p, q, r, and s in This Mathematical Problem?
  • Thread starter Thread starter anemone
The mathematical problem involves determining the values of positive real numbers p, q, r, and s that satisfy the equations p + q + r + s = 12 and pqrs = 27 + pq + pr + ps + qr + qs + rs. Using the AM-GM inequality, it is established that pqrs must equal 81, leading to the conclusion that p, q, r, and s must all be equal to 3. This conclusion arises because equality in the AM-GM inequality occurs only when all variables are equal. Although the solution is confirmed, the discussion raises the question of whether other solutions exist, suggesting further exploration with different initial values. Ultimately, the consensus is that p = q = r = s = 3 is the only solution that meets the given conditions.
anemone
MHB
POTW Director
Hi MHB,
I have encountered a problem and I am not being able to figure out the answer.
Problem:
Given that $p, q, r, s$ are all positive real numbers and they satisfy the system
$p+q+r+s=12$
$pqrs=27+pq+pr+ps+qr+qs+rs$
Determine $p, q, r$ and $s$.
Attempt:
The AM-GM inequality for both $p, q, r, s$ and $pq,pr,ps,qr,qs,rs$ are:
[TABLE="class: grid, width: 700"]
[TR]
[TD]1.[/TD]
[TD]$\dfrac{p+q+r+s}{4} \ge \sqrt[4]{pqrs}$ which then gives $(\dfrac{12}{4})^4 \ge pqrs$ or $pqrs \le 81$[/TD]
[/TR]
[TR]
[TD]2.[/TD]
[TD]$\dfrac{pq+pr+ps+qr+qs+rs}{6} \ge \sqrt[6]{(pqrs)^3}$
which then gives $(\dfrac{pqrs-27}{6})^2 \ge pqrs$
$(pqrs-81)(pqrs-81) \ge 0$
$pqrs \le 9$ or $pqrs \ge 81$[/TD]
[/TR]
[/TABLE]
After that, I don't see how to proceed...should I conclude that since we need to find $pqrs$ that satisfy both of the inequalities below
$pqrs \le 81$ and $pqrs \ge 81$
$\therefore pqrs=81$ and and obviously the answer would be $p=q=r=s=3$?
Mathematics news on Phys.org
On your second AM-GM inequality, you get $(pqrs-81)(pqrs-9) \ge 0$, with the individual inequalities that you found.
In the beginning of the problem, you specified that $p,q,r,s$ are real. Is that correct? If so, I see no way of nailing down all four values, given only two equations. Certainly, $p=q=r=s=3$ works, but what guarantee do we have that there isn't another solution? E.g., try setting $p=q=2$, and solving the resulting system for $r,s$, and see if there is a solution.
[EDIT] See Opalg's post below for a correction.
anemone said:
Hi MHB,
Problem:
$p+q+r+s=12$
Attempt:
[TR]
[TD]1.[/TD]
[/TR]
[TR]
[TD]2.[/TD]
[/TR]
[/TABLE]
It looks as though you have solved this problem. You have shown that either $pqrs\leqslant9$ or $pqrs\geqslant 81$. But the equation $pqrs=27+pq+pr+ps+qr+qs+rs$ shows that $pqrs\geqslant27$, so that rules out the first of those possibilities. We are left with the second one, $pqrs\geqslant 81$. But you have also shown that $pqrs\leqslant 81$. Therefore $pqrs = 81$. That implies that equality occurs in the AM-GM inequality, and that only happens when all four quantities are equal. So $p=q=r=s=3$.
Thanks Ackbach for your reply.
Opalg said:
...We are left with the second one, $pqrs\geqslant 81$. But you have also shown that $pqrs\leqslant 81$. Therefore $pqrs = 81$. That implies that equality occurs in the AM-GM inequality, and that only happens when all four quantities are equal. So $p=q=r=s=3$.
Hi Opalg, thank you so much for pointing out that equality holds in the AM-GM inequality only if all of the quantities involved are equal...this is something I have totally forgotten about.:o
I understand it all now! Thanks guys!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
