How can I effectively solve a system of congruences?
  • Thread starter Thread starter bremenfallturm
    System
To effectively solve a system of congruences, the Chinese Remainder Theorem (CRT) is recommended, especially since the moduli are coprime. The discussion highlights the importance of finding a particular solution and understanding that solutions can be expressed in the form of x = x_p + k * LCM(n1, n2), where LCM is the least common multiple of the moduli. The participants also emphasize the need to grasp the underlying principles of diophantine equations, as well as the significance of recognizing that the solutions repeat every 648 units due to the product of the coprime moduli (8 and 81). Overall, a methodical approach, possibly aided by computational tools, can clarify the solution process.
bremenfallturm
81
Find all integers so that ##x\equiv_8 5## and ##x\equiv_{81} 73##
##x=c\pmod{n} \equiv x=n\cdot k + c## for an integer ##k##
My attempt.
I think it might be that I solve the diophantine equation wrong, according to my anwer key it should be
I do not get a particular solution that is close to 397 as you can see.
bremenfallturm said:
Homework Statement: Find all integers so that ##x\equiv_8 5## and ##x\equiv_{81} 73##
Relevant Equations: ##x=c\pmod{n} \equiv x=n\cdot k + c## for an integer ##k##
My attempt.
I just cranked it out from first principles. Just keep going from the point you gave up:
Where is odd etc.
Isn't ?
Have you seen the Chinese Remainder Theorem?
fresh_42 said:
No, my lecturer explicitly said that it's not "part of the course". But looks like it's good to solve this assignment.
fresh_42 said:
Btw.: Here is explained how you write Formulas: https://www.physicsforums.com/help/latexhelp/
If sorry if what I wrote was hard to read. I do know about formulas, in fact I'm a huge fan. I exported my original solution but if hard to read I can consider rewriting all my solutions into TeX.
I realized I made a mistake when I wrote that is unsolveable with the inverse. In fact there exists an inverse and I got closer by using that instead:
(I hope that my handwritten notes are OK to post. If you can't read them please let me know and I'll rewrite them into TeX)
So now I found the correct value for , but I don't understand where the part in the answer key comes from. Thankful for any help!
I realized I made a mistake when I wrote that ##8k\equiv 68\pmod{81}## is unsolveable with the inverse.
So now I found the correct value for ##x##, but I don't understand where the ##+648n## part in the answer key comes from. Thankful for any help!
I don't really understand the difficulty:
The left-hand side is even, hence is even. Let .
And, again, is even:
Now, must be odd ...
So now I found the correct value for x, but I don't understand where the +648n part in the answer key comes from.
and are coprime. So every numbers, you will get the same remainders for both of them. This means that can only be unique up to multiples of
I think I'm having a hard time with this assignment because I:
(1) Have not learned about the Chinese root theorem
(2) Have not seen a similar assignment before
(3) Am very new to solving diophantine equations so
(4) I tend to approach solving them in one, very mechanical way:
1. Rewrite the equation
2. Get a particular solution, either by directly seeing it or doing Euclidean algorithm in reverse
3. Given the particular solution we get
So when I encounter ways of solving diophantine equations that do not seem to do it in the way that I explained in (4), I get confused.
In your particular proposition, I do not see what insight I should get from that is odd.
fresh_42 said:
##8## and ##81## are coprime. So every ##8\cdot 81=648## numbers, you will get the same remainders for both of them. This means that ##x## can only be unique up to multiples of ##648.##
This I understand intuitively now that you told me, but as I explained above (in (4)), I still approach diophantine equations in a very mechanical way. I would expect to be the result of as in (explained in (4.3) above). But I can't connect the fact that to my familar formulas (and I don't know where would come from in the first case), so I just have a hard time seeing the intuition behind the solution since I can't connect it to anything that I've worked with before.
If that makes any sense at all.
1. Rewrite the equation ##a\equiv b\pmod n\implies a=xn+bk\implies xn-bk=a##
3. Given the particular solution ##x_p## we get ##x=x_p+\frac{b}{gcd(n,b)}c, c\in \mathbb Z##
In your particular proposition, I do not see what insight I should get from that ##m_2## is odd.
This I understand intuitively now that you told me, but as I explained above (in (4)), I still approach diophantine equations in a very mechanical way. I would expect ##648## to be the result of ##\frac{b}{gcd(n,b)}## as in ##x=x_p+\frac{b}{gcd(n,b)}c, c\in \mathbb Z## (explained in (4.3) above). But I can't connect the fact that ##648=8\cdot 81## to my familar formulas (and I don't know where ##b## would come from in the first case), so I just have a hard time seeing the intuition behind the solution since I can't connect it to anything that I've worked with before.
I suggest you first follow the way @PeroK has outlined. The only other method I know of would be the CRT (Chinese Remainder Theorem) and Wikipedia shows an algorithm for it. Without using it, use @PeroK's step-by-step method!
For the problematic, imagine you got a solution The CRT got me I haven't done it differently, so you might find or e.g. or or whatever. Say you got Then you can mark it by the pair of remainders modulo and respectively. If you next color every eight numbers blue on the number line in both directions and every eighty-one numbers red on the number line in both directions, then is colored blue and red. Now, what will be the other numbers that are both, red and blue? All of them satisfy the conditions and simultaneously. All other numbers are either uncolored, only blue, or only red.
I didn't use that.
I thought my method was mechanical.
The question asks for integers whose remainder is 5 on division by 8 and whose remainder is 73 on division by 81. There must be an elementary solution for that. The only trick I used was to note where the second integer () was odd or even and break it down further.
The other thing you should do is check that the numbers you get () all satisfy both the original equations. That's good practice even when you have a book answer.
Another suggestion is to use a spreadsheet or write a computer program to do this. Here's a spreasheet. The first column starts at 73 and each row is the previous row plus 81. The second column is the first column mod 8. You can see the simple pattern as 8 and 81 are coprime (as identified by @fresh42). The third colum uses an IF to pick out where the second column is 5. The fourth column I did by hand to show the difference in the X's. And there's the answer!
x (73)mod 8
73​
1​
154​
2​
235​
3​
316​
4​
397​
5​
X
478​
6​
559​
7​
640​
0​
721​
1​
802​
2​
883​
3​
964​
4​
1045​
5​
X
648​
1126​
6​
1207​
7​
1288​
0​
1369​
1​
1450​
2​
1531​
3​
1612​
4​
1693​
5​
X
648​
1774​
6​
1855​
7​
1936​
0​
2017​
1​
2098​
2​
2179​
3​
2260​
4​
2341​
5​
X
648​
x (73)mod 8
73​
1​
154​
2​
235​
3​
316​
4​
397​
5​
X
478​
6​
559​
7​
640​
0​
721​
1​
802​
2​
883​
3​
964​
4​
1045​
5​
X
648​
1126​
6​
1207​
7​
1288​
0​
1369​
1​
1450​
2​
1531​
3​
1612​
4​
1693​
5​
X
648​
1774​
6​
1855​
7​
1936​
0​
2017​
1​
2098​
2​
2179​
3​
2260​
4​
2341​
5​
X
648​
The number line in modern times!
