MHB How Can I Express a Combination of Logarithms as a Single Logarithm?
  • Thread starter Thread starter cbarker1
    Logarithms
To express the combination of logarithms as a single logarithm, start by applying the power rule to rewrite the expression as $\log_{d}(a^4) - \log_{d}(b^{5/6}) + \log_{d}(c^{2/3})$. Use the properties of logarithms: the sum of logarithms corresponds to multiplication, and the difference corresponds to division. The final expression can be simplified to $\log_{d}\left(a^4 \sqrt[6]{\frac{c^4}{b^5}}\right)$. The order of combining terms does not affect the final result, allowing flexibility in the approach.
cbarker1
MHB
Express as a Single Logarithm. Assume all the logarithms have the same base. The problem is:
$4*\log_{d}\left({a}\right)-\frac{5}{6}*\log_{d}\left({b}\right)+\frac{2}{3}*\log_{d}\left({c}\right)$, where $d\gt1$
then I use the power rule for logarithm for the beginning and use some grouping symbols for last two:
$\log_{d}\left({a^4}\right)-(\frac{5}{6}\log_{d}\left({b}\right)+\frac{2}{3}\log_{d}\left({c}\right))$
Afterwards, I combine the coeffecients of the logarithms to be the common denominator of one sixth :
$\log_{d}\left({a^4}\right)-(\frac{5}{6}\log_{d}\left({b}\right)+\frac{4}{6}\log_{d}\left({c}\right))$
Here is where I have some trouble. Do I factor the one-sixth;then, use the sum-multiplication inside the group symbol or use the power again and the sum-multiplication rule for log inside the grouping symbol like this:
$\log_{d}\left({a^4}\right)-(\frac{5}{6}\log_{d}\left({b}\right)+\frac{4}{6}\log_{d}\left({c}\right))$ to
$\log_{d}\left({a^4}\right)-(\frac{1}{6}({5}\log_{d}\left({b}\right)+4\log_{d}\left({c}\right)))$
from that to this
$\log_{d}\left({a^4}\right)-(\frac{1}{6}(\log_{d}\left({b^5*c^4}\right))$
to $\log_{d}\left({a^4}\right)-\frac{1}{6}(\log_{d}\left({b^5*c^4}\right))$
Or
$\log_{d}\left({a^4}\right)-(\log_{d}\left({\sqrt[6]{b^5}}\right)+\log_{d}\left({\sqrt[6]{c^4}}\right))$
$\log_{d}\left({a^4}\right)-(\log_{d}\left({\sqrt[6]{b^5}*\sqrt[6]{c^4}}\right))$
$\log_{d}\left({a^4}\right)-(\log_{d}\left({\sqrt[6]{b^5*c^4}}\right))$
What to do next?Thank you
Cbarker1
Mathematics news on Phys.org
I think you can skip a lot of the intermediate steps you are taking. It's not wrong the way you're doing it though.
$$4*\log_{d}\left({a}\right)-\frac{5}{6}*\log_{d}\left({b}\right)+\frac{2}{3}*\log_{d}\left({c}\right)$$
$$\log_{d}\left({a^4}\right)-\log_{d}\left({b}^{\frac{5}{6}} \right)+\log_{d}\left({c}^{\frac{2}{3}}\right)$$
From here you need to remember two rules:
1) $$\log_{d}\left({a}\right)+\log_{d}\left({b}\right)=\log_{d}\left({ab}\right)$$
2) $$\log_{d}\left({a}\right)-\log_{d}\left({b}\right)=\log_{d}\left({\frac{a}{b}}\right)$$
Combine any two terms into one, then combine that with the third term. Simplify if possible at the end and keep powers written in fractional form until the end too.
Should I use the quotient to difference rule or the sum to multiplication rule first?The answer in the back of the book is $\log_{d}\left({a^4\sqrt[6]{\frac{c^4}{b^5}}}\right)$
It doesn't matter. You'll get the same answer either way, which is why I wrote pick any two terms to combine. If it's easier for you to stick with terms left to right then try combining the first two and see what you get. :)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
10K
10K
11K
