MHB How can I factor a polynomial without using the rational root theorem?
Factoring the polynomial \(6x^4+17x^3-24x^2-53x+30\) can be achieved without the rational root theorem by grouping terms and using trial and error. The polynomial can be rewritten as \((x+2)(x+3)(2x-1)(3x-5)\) through strategic grouping and simplification. The process often involves guesswork to identify pairs of numbers that facilitate factoring. One participant mentioned using Wolfram Alpha for assistance in determining the factors. Overall, the discussion highlights the combination of analytical methods and computational tools in polynomial factorization.
paulmdrdo1
I'm just curious as to how to go about factoring a polynomial like this one $6x^4+17x^3-24x^2-53x+30$ without using rational root theorem?
Thanks
Mathematics news on Phys.org
You could write:
$$6x^4+17x^3-24x^2-53x+30=\left(6x^4+12x^3\right)+\left(5x^3+10x^2\right)-\left(34x^2+68x\right)+\left(15x+30\right)=6x^3(x+2)+5x^2(x+2)-34x(x+2)+15(x+2)=(x+2)\left(6x^3+5x^2-34x+15\right)$$
$$6x^3+5x^2-34x+15=\left(6x^3+18x^2\right)-\left(13x^2+39x\right)+\left(5x+15\right)=6x^2(x+3)-13x(x+3)+5(x+3)=(x+3)\left(6x^2-13x+5\right)$$
$$6x^2-13x+5=(2x-1)(3x-5)$$
And so we have:
$$6x^4+17x^3-24x^2-53x+30=(x+2)(x+3)(2x-1)(3x-5)$$
MarkFL said:
You could write:
And so we have:
What technique did you use to determine the pair of numbers to be used to rewrite the expression? Was it by trial and error?
Yes, there is generally guesswork involved in factoring polynomials. What I actually did was used W|A to factor it, and then constructed my post based on that. :D
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
