How can I find Horizontal and Vertical velocity, given distance and time?
In summary, the conversation discussed finding horizontal and vertical vectors at different points of a projectile's path. The equation for finding the maximum height was also explored, and it was determined that the acceleration is constant throughout the path. A sub question regarding the trend of acceleration at the end of the path was also addressed.
kayte
I need to find the horizontal vectors and vertical vectors at launch, maximum height and at final catch of a projectile. I know that the distance between point A and point B is 5 and the total time is 1.
How can I also find the maximum height and the acceleration?
Vx (would this be horizontal vector?) = d/t = 5 m/1 s = 5 m/s
Vy (would this be vertical vector?) = Vinitial + aΔt = (and i got stuck here because I'm not sure what v initial is equal to.)
welcome to pf!
hi kayte! welcome to pf! :smile:
(try using the X2 button just above the Reply box :wink:)
yup! :smile:
you don't need vinitial, that's what you're trying to find! :wink:
you have a and t and (y - yinitial) = 0, and you want vinitial
so choose one of the standard constant acceleration equations that uses a t y and v …
show us what you get :smile:
okay... so i chose to use the equation Δy=vinitialΔt+(1/2)a(Δt)2
knowing the given:
Δt=1 s
a=0 m/s2 (because it's constant)
i substitute:
∆y=vinitial(1)+(1/2)(0)(1)2
∆y=vinitial+0
∆y=vinitial
and I'm stuck here... :frown: would i need to know max height of the path to find ∆y?
hi kayte! :smile:
(just got up :zzz:)
you're confused between v constant and a constant …
a is -g :wink:
(and if A and B are at the same height, then t = 1 isn't at y = maximum, is it?)
oh O:
so...
Δt=.5 s (because the max height is in the middle)
a=-9.81 m/s2
∆y=vinitial(.5)+(1/2)(-9.81)(.5)2
∆y=(.5)vinitial+1.22625
hmm … 2 variables, only 1 equation :frown:
try using ∆t = 1, ∆y = 0 o:)
alrighty, so...
0=vinitial(1)+(1/2)(-9.81)(1)2
0=vinitial-4.905
4.905=vinitial
this will be the vectors at catch point because time is 1 and height is 0?
kayte said:
alrighty, so...
0=vinitial-4.905
4.905=vinitial
looks ok :smile:
now you can find ∆y for t = 1/2 ! :wink:
this will be the vectors at catch point …
i don't understand :confused:
ohh, like why did you tell me to use y=0? is that like the start/end of the path of the projectile?
because you know both y and t at that point …
you didn't know both y and t at the top point :wink:
hmm... oh! i see
haha :wink:
one more question. what does the phrase "acceleration at end" mean and how can i find it?
where does it come from? :confused:
(it's not in the question, and every projectile has the same acceleration anyway)
it's a sub question dealing with trends as distance increases
are we still talking about projectiles?
can you give a quote? :confused:
yes we are
"As distance increases, what trend(s) do you see in the values for 'acceleration at end'?"
the acceleration is constant :confused:
alrighty. thank you so much for your help! :biggrin:
Related to How can I find Horizontal and Vertical velocity, given distance and time?
1. What is the formula for calculating horizontal and vertical velocity?
The formula for calculating horizontal and vertical velocity is v = d/t, where v is the velocity, d is the distance, and t is the time.
2. How can I find the horizontal and vertical velocity if only given the distance and time?
If you are given the distance and time, you can use the formula v = d/t to find the velocity. Simply plug in the values for distance and time and solve for velocity.
3. Is there a difference between horizontal and vertical velocity?
Yes, horizontal and vertical velocity are different. Horizontal velocity refers to the speed of an object moving horizontally, while vertical velocity refers to the speed of an object moving vertically.
4. Can I use the same formula to calculate horizontal and vertical velocity?
Yes, the same formula v = d/t can be used to calculate both horizontal and vertical velocity. However, it is important to make sure you are using the correct distance and time values for each velocity.
5. Are there any other factors that affect horizontal and vertical velocity besides distance and time?
Yes, there are other factors that can affect horizontal and vertical velocity, such as air resistance, gravity, and the angle of the object's motion. These factors can alter the velocity and should be taken into consideration when making calculations.
