How can I find the derivative of ln(sin5x)?
  • MHB
  • Thread starter DeusAbscondus
  • Tags
    Derivative
In summary, the conversation was about finding the derivative of a function involving an embedded function using the Chain rule of differentiation. The participants also discussed the concept of composition of functions and provided examples of using the chain rule. Finally, Sudharaka mentioned a helpful video on Khan Academy for further understanding.
DeusAbscondus
176
Hi folks,
For some reason, the following does not make sense to me:
If 1. $$f(x)=ln(sin(5x))$$ then 2. $$f'(x)=5cot(5x)$$ but I can only get as far as
$$f(x)=ln(sin(5x))\implies\frac{1}{u}*5cosx=\frac{5cos(x)}{sin(5x)}$$
Can someone please show me how to get from here to 2.? Thanks kindly, DeusAbs
DeusAbscondus said:
Hi folks,
Hi DeusAbscondus, :)
What you need here is the Chain rule of differentiation. Please refer the link given and try to understand how to use this rule so that you can easily differentiate the given function.
\[f(x)=\ln(\sin(5x))\]
Using the chain rule of differentiation we can write,
\[\frac{d}{dx}f(x)=\frac{d}{d(\sin(5x))}f(x)\frac{d}{dx}\sin(5x)\]
Try to continue from here. :)
Kind Regards,
Sudharaka.
DeusAbscondus said:
Hi folks,
The derivative of \(\sin(5x)\) is \(5 \cos(5x)\) not \( 5\cos(x)\).CB
DeusAbscondus said:
Hi folks,
I'll do this by substitution to make it easier to see. On an exam you'd be fine to just go with it.
Let
  • $u(x) = 5x$
  • $v(u) = \sin(u)$
  • $y(v) =\ln(v)$
Their respective derivatives are
  • $\dfrac{du}{dx} = 5$
  • $\dfrac{dv}{du} = \cos(u)$
  • $\dfrac{dy}{dv} = \dfrac{1}{v}$
The chain rule states that
$ \dfrac{dy}{dx} = \dfrac{du}{dx} \cdot \dfrac{dv}{du} \cdot \dfrac{dy}{dv}$In other words multiply your three derivatives together and simplify
$\dfrac{dy}{dx} = 5 \cdot \cos(5x) \cdot \dfrac{1}{\sin(u)}$
$\dfrac{dy}{dx} = 5 \cdot \cos(5x) \cdot \dfrac{1}{\sin(5x)}$
$\dfrac{dy}{dx} = \dfrac{5cos(5x)}{\sin(5x)}$
Use your trig identities to simplify into the desired format
Supplementary question: Re: derivative of ln(sin5x)
Super! simply super, thanks for such a full demonstration: really appreciated.
C'n Black: I'm coming to enjoy your laconic exactitude: thank you kindly.
Sudharaka: prompt, friendly, accurate and complete: thanks friend.
It was obvious to me that I was missing something basic: to wit: $$sin(5x)$$calls for the chain rule, since it contains an embedded function.
Supplementary Question: does this mean that whenever the argument of a function - the $x$ bit - contains more than $x$, that one is dealing with an embedded function? (excluding of course the cases of simple derivative addition and subtraction)? Please, could one of you chaps come up with language that tidies up what I think I am right in trying to say here?
this has opened the afternoon up for me to pleasantly work away at 40 examples of a similar kind, so as to root this shared logic into my mathematically growing but immature brain.
DeusAbs
Re: Supplementary question: Re: derivative of ln(sin5x)
You are welcome. :)
Yes. In mathematical language what you have is a composition of functions. Examples of using the chain rule,
\[f(x)=\sin(5x)\Rightarrow\frac{d}{dx}f(x)=\frac{d}{d(5x)}\sin(5x)\frac{d}{dx}(5x)=5\cos(5x)\]
\[f(x)=\sin(x+10)\Rightarrow \frac{d}{d(x+10)}\sin(x+10)\frac{d}{dx}(x+10)=\cos(x+10)\]
A useful video giving examples of using the chain rule can be found http://www.khanacademy.org/math/calculus/v/chain-rule-examples.
Kind Regards,
Sudharaka.
Sudharaka said:
You are welcome. :)
\[f(x)=\sin(10x)\Rightarrow\frac{d}{dx}f(x)=\frac{d}{d(5x)}\sin(5x)\frac{d}{dx}(5x)=5\cos(5x)\]
Kind Regards,
Sudharaka.
Sudharaka, thanks, but are you sure you have not made an inadvertant error here:
$$f(x)=\sin(10x)\implies f'(x)=10cos(10x)$$
doesn't it?
DeusAbs
doesn't it?
DeusAbs
Yes, sorry. Corrected it. :)
follow up regarding "special result" in my calc text
I'm trying to satisfy my mind as to why $$ f(x)=5ln(x) \Rightarrow f'(x)=5.\frac{1}{x}=\frac{5}{x}$$
Is it valid because of the result
$$ kf(x) \Rightarrow \frac{dy}{dx}=kf'(x) where 'k' is some constant$$
If so, could someone please make some brief comments illuminating this result, its proof and application (with couple of simple examples)
Thanks kindly folks, always, for the incalculable power of good you are doing me with your help.
DeusAbs
Incidentally,
i) how do I space English words in latex expressions to avoid the ugly running together of letters as in above, and
ii) is there a backslash command for If/then?, or
iii) is my use of $\Rightarrow$ appropriate for If/then expressions?
Hi DeusAbscondus,
Yes, you are correct that for constant k, \(\displaystyle \frac{d}{dx}k \cdot f(x)=k \cdot f'(x)\) and for that reason if \(\displaystyle f(x)=5\ln(x)\) then \(\displaystyle f'(x)=5 \cdot \frac{1}{x}=\frac{5}{x}\).
To answer one of your other questions. You can use the Latex command \text{ } to add normal looking text.
\(\displaystyle \text{You can see this in effect right here}\)
Jameson said:
Hi DeusAbscondus,
Thanks kindly Jameson (btw: I thoroughly approve of the change of image, which is in keeping with the wry, comic -gently self-ironizing- tone of the former, KGB avatar; i like it!)
I love this place! The sense of support is enormous.
Yesterday I had a day during which I felt defeated by the seeming enormity of the task of learning all this stuff; after a couple of interactions here, I *always* get enlightened and/or instructed, and this, in turn, lifts my mood and encourages me to keep going.
So, now I can go $$\text{If } y=x^2\text{ then } y'=2x\text{...how cool is that}$$
Argggh, but I still have the spacing problem, even after using \text{*} (?!)
I'm really glad you like the site. Hearing that is why I love working here, as well as getting to interact with some great minds.
I've edited your post for you to include the spaces. If you add a space inside the \text{ } then it will appear. For example:
1) \text{The derivative of} x^2 \text{is} 2x yields \(\displaystyle \text{The derivative of} x^2 \text{is} 2x\). Notice the problem in spacing.
2) If I add spaces inside the text tag like so: \text{The derivative of } x^2 \text{ is } 2x we get \(\displaystyle \text{The derivative of } x^2 \text{ is } 2x\)
See the difference? :)
Re: follow up regarding "special result" in my calc text
This is a consequence of the constant factor rule in differentiation. You can find the proof on this page. Examples can be found here.
The symbol \(\Rightarrow\) is used for implication. Since \(y=kf(x)\) implies \(\frac{dy}{dx}=kf'(x)\) it is correct to write, \(y=kf(x)\Rightarrow \frac{dy}{dx}=kf'(x)\). Refer this.
Kind Regards,
Sudharaka.
DeusAbs
Incidentally,
By definition:
\[\frac{d}{dx}f(x)=\lim_{h \to 0}\frac{f(x+h)-f(x)}{h}\]
so:
\[\begin{aligned} \frac{d}{dx}\left(k\; f(x)\right)&=\lim_{h \to 0}\frac{k\;f(x+h)-k\;f(x)}{h} \\ &= \lim_{h \to 0}\left(k\; \frac{f(x+h)-f(x)}{h}\right)\\ &= k\; \lim_{h \to 0} \frac{f(x+h)-f(x)}{h}\\ &= k\frac{d}{dx}f(x) \end{aligned}\]
CB
CaptainBlack said:
By definition:
so:
\[\frac{d}{dx}\left(k\; f(x)\right)=\lim_{h \to 0}\frac{k\;f(x+h)-k\;f(x)}{h} = \lim_{h \to 0}\left(k\; \frac{f(x+h)-f(x)}{h}\right) = k\; \lim_{h \to 0} \frac{f(x+h)-f(x)}{h}\ = k\frac{d}{dx}f(x)\]
CB
Thanks Cap'n.
Could you go one step further and instance the use of $\frac{dy}{dx}$ as opposed to $\frac{d}{dx}$ so as to make plain to me the logic and syntax of the one compared to the other?
Much appreciated,
DeusAbs
DeusAbscondus said:
Thanks Cap'n.
Much appreciated,
DeusAbs
Usually \(\displaystyle \frac{dy}{dx}=f'(x)=y'\) meaning the derivative of function y with respect to x. Nothing necessarily needs to be calculated. All three of those things just represent the idea of the derivative of y with respect to x.
On the other hand, \(\displaystyle \frac{d}{dx}\) means calculate the derivative of whatever follows with respect to x.
Example:
\(\displaystyle y=x^2\) so \(\displaystyle \frac{d}{dx}x^2=2x=\frac{dy}{dx}\)
With \(\displaystyle \frac{d}{dx}\) something must follow that or it doesn't make sense. \(\displaystyle \frac{dy}{dx}\) can stand on its own.
Ah! Formidable, mon vieux!
This is exactly what I came on to find out about tonight! and here, you left me word to that effect days ago!
$\text{ Thanks again ... Jameson ... }$:)
FAQ: How can I find the derivative of ln(sin5x)?
What is the derivative of ln(sin5x)?
The derivative of ln(sin5x) is cos(5x) / sin(5x).
How do you find the derivative of ln(sin5x)?
To find the derivative of ln(sin5x), you can use the chain rule and the derivative of ln(x) = 1/x. First, take the derivative of inside function sin5x, which is cos(5x). Then, multiply it by the derivative of the outside function ln(x), which is 1/x. The final result is cos(5x) / sin(5x).
What is the domain of ln(sin5x)?
The domain of ln(sin5x) is all real numbers except for values that make sin5x = 0, since ln(0) is undefined. This occurs when x = 0, π, 2π, etc.
How do you graph the derivative of ln(sin5x)?
The graph of the derivative of ln(sin5x) can be obtained by plotting the derivative function, cos(5x) / sin(5x), on a graphing calculator or by hand. The resulting graph will be a periodic function with a period of 2π and will have vertical asymptotes at x = 0, π, 2π, etc.
What are the applications of the derivative of ln(sin5x)?
The derivative of ln(sin5x) has applications in various fields such as physics, engineering, and economics. It can be used to model the behavior of waves, oscillations, and other periodic phenomena. It can also be used in optimization problems, where you need to find the maximum or minimum value of a function. Additionally, it is used in the study of elasticity and in financial derivatives such as options and futures contracts.
