How can I find the equation of a line given its x-intercept and y-intercept?
  • MHB
  • Thread starter mathdad
In summary, if you are interested in the two-intercept form of a line, you can use the given intercepts to determine the slope, and then use the slope-intercept form.
mathdad
1,283
Find an equation of the line whose x-intercept is -6 and y-intercept is sqrt{6}.
1. The x-intercept is the point (-6, 0) and y-intercept can be written as the point (0, sqrt{6}).
Yes?
2. After finding my two points, I must find the slope.
True?
3. I then plug the slope and one of the points into the point-slope formula and solve for y.
Yes?
Mathematics news on Phys.org
Yes?
Yes.
True?
Yes.
Yes?
Yes.
It may interest you to know that the two-intercept form of a line may be written:
\(\displaystyle \frac{x}{a}+\frac{y}{b}=1\)
Where the $x$-intercept is $(a,0)$ and the $y$-intercept is $(0,b)$. If you're interested, see if you can derive the above formula...:)
To derive the formula, must I use the points (a,0) and (0,b)? Must I also use y = mx + b?
You can use the two given intercepts to determine the slope, and then use the slope-intercept form, yes.
Let m = slope
m = (sqrt{{6} - 0)/(0 -(-6))
m = sqrt{6}/6
I will use (-6,0).
y - 0 = (sqrt{6}/6)(x - (-6))
y = (sqrt{6}/6)(x + 6)
y = (sqrt{6})x + sqrt{6}
Correct?
Let m = slope
m = (b - 0)/(0 - a)
m = b/-a
y = mx + b
y = (b/-a)x + b
Where do I go from here?
RTCNTC said:
Let m = slope
m = (b - 0)/(0 - a)
m = b/-a
y = mx + b
y = (b/-a)x + b
Divide through by $b$...
Let m = slope
m = (b - 0)/(0 - a)
m = b/-a
y = mx + b
y = (b/-a)x + b
y/b = (b/-a)x(1/b) + (b/b)
y/b = -x/a + 1
(x/a) + (y/b) = 1
- - - Updated - - -
Can you give me an example using (x/a) + (y/b) = 1 to solve a problem?
RTCNTC said:
...Can you give me an example using (x/a) + (y/b) = 1 to solve a problem?
The problem you originally posted in post #1 would be such an example. :)
Cool. I will post several more questions from the David Cohen Precalculus 3rd Edition later tonight. I believe you also have this textbook.
FAQ: How can I find the equation of a line given its x-intercept and y-intercept?
What is the equation of a line?
The equation of a line is a mathematical representation of a straight line on a graph. It is typically in the form of y = mx + b, where m is the slope of the line and b is the y-intercept, which is the point where the line crosses the y-axis.
How do you find the equation of a line?
To find the equation of a line, you need to know at least two points on the line. You can then use the coordinates of these points to calculate the slope m using the formula m = (y2 - y1) / (x2 - x1). Once you have the slope, you can plug it into the equation y = mx + b and solve for b using one of the points. This will give you the complete equation of the line.
What is the slope-intercept form of a line?
The slope-intercept form of a line is y = mx + b, where m is the slope and b is the y-intercept. This form is useful for graphing a line, as it tells you the slope and y-intercept of the line.
Can the equation of a line have fractions?
Yes, the equation of a line can have fractions. This often happens when the slope is not a whole number. For example, the equation of a line with a slope of 3/4 would be y = (3/4)x + b.
How does the equation of a line change if the line is horizontal or vertical?
If a line is horizontal, its slope is 0 and the equation becomes y = b, where b is the y-intercept. If a line is vertical, it has an undefined slope and the equation becomes x = a, where a is the x-intercept. In both cases, the line is still in the form of y = mx + b, but with special values for m and b.
