How can I find the maximum KE of the photoelectrons?
In summary, the conversation discusses the concepts of kinetic energy, photon energy, and the photoelectric equation. The photoelectric equation states that a photon must have enough energy to overcome the work function in order to release a photoelectron, and any leftover energy is given by KE=hf-work function. The conversation also touches on the relationship between photon energy and frequency, and how this is related to the energy difference between energy levels in a single atom.
sodnaz
I don't know how to do Question 2 part C.
I know that E=hf and I know the photoelectric equation: hf = work function + 1/2mv^2
I honestly don't have a clue how to do part c of question 2. I think it involves one of the two equations I said above, but I'm not sure which one it would be and why. Could someone help me please?
Thank you
You are looking for kinetic energy, so which of the equations you posted looks more promising?
I'm not sure, since they would both be kinetic energy wouldn't they (since for E=hf, the photons have kinetic energy since they are moving)? Or is the first one (E=hf) not for kinetic energy?
Photons have energy and momentum but zero mass. Their energy is E = hf and their momentum is p = hf/c. Besides, you are asked to find the kinetic energy of the electrons and that's KE = ½mv2.
But since the photons are traveling through the air, their energy must be kinetic energy, right? I know I need to find the KE of the photoelectrons but I'm asking about normal photon energy here, the incident photons.
Photons have only one kind of energy and that's hf. All photons have zero mass and travel at the speed of light in vacuum. Thus, it doesn't make sense to talk about their kinetic energy ½mv2. That's why we do not attach the qualifier "kinetic" to the photon energy.
In any case, do you understand what the photoelectric equation says? Can you explain it in simple terms? Understanding that should help you figure out how to answer the question.
Ah, that explains the question regarding the KE, thank you.
I know that the photoelectric equation basically says, a photon of energy hf has to overcome the work function in order to release a photoelectron, and any "spare energy" left over (given by KE=hf-work function) is KE of the photoelectron.
I don't know how I use that equation with part c though. Do I just say that the KE = hf - work function? If it's that easy, how would you integrate it with those energy levels shown just below the question? How do they come into these equations?
You just say that. Think of the electron as absorbing all of the photon's energy. It uses some of the energy (equal to the work function) to pay the metal for its freedom. Any energy that's left after the electron leaves the surface, is kinetic energy that it spends however the circumstances dictate.
It's that easy, but unrelated to the energy levels. That part of the question has to do with photon (not electron) emission by a single atom. The energy of the emitted photon must match the energy difference between levels.
For question 3a: So if the energy of the emitted photon matches the energy differnece, and change in E = hf, then to find the frequency it would be change in energy/planck's constant, aka delta E/h = f? Then I use that value of f in E=hf?
sodnaz said:
... then to find the frequency it would be change in energy/planck's constant, aka delta E/h = f?
Yes.
No reason to do that. You already know that the energy of the photon is the energy difference between levels. You will be going around a circle if you did that.
Related to How can I find the maximum KE of the photoelectrons?
1. What is the equation for calculating the maximum kinetic energy of photoelectrons?
The equation is KEmax = hf - Φ, where KEmax is the maximum kinetic energy, h is Planck's constant, f is the frequency of the incident light, and Φ is the work function of the material.
2. How does the frequency of the incident light affect the maximum kinetic energy of photoelectrons?
The maximum kinetic energy of photoelectrons is directly proportional to the frequency of the incident light. This means that as the frequency increases, so does the maximum kinetic energy.
3. What is the significance of the work function in determining the maximum kinetic energy of photoelectrons?
The work function is the minimum amount of energy required to remove an electron from the surface of a material. It serves as a barrier for the emission of photoelectrons, and the difference between the incident light's energy and the work function determines the maximum kinetic energy of the emitted electrons.
4. Can the maximum kinetic energy of photoelectrons be greater than the incident light's energy?
No, the maximum kinetic energy of photoelectrons can never be greater than the energy of the incident light. This is because the work function serves as a limit for the energy of emitted electrons.
5. What factors can affect the accuracy of calculating the maximum kinetic energy of photoelectrons?
The accuracy of calculating the maximum kinetic energy of photoelectrons can be affected by factors such as the experimental setup, the purity of the material, and external factors like temperature and pressure. It is important to control for these variables to obtain accurate results.
  • Quantum Physics
