How can I find this displacement?
In summary: ##y_i## is the value of the function at the left endpoint of the ##i^{th}## interval while ##x_i## is the left endpoint of the ##i^{th}## interval.
GaussianSurface
Your task is to estimate how far an object traveled during the time interval 0≤t≤8, but you only have the following data about the velocity of the object.
*First image
You decide to use a left endpoint Riemann sum to estimate the total displacement. So, you pick up a blue pen and draw rectangles whose height is determined by the velocity measurement at the left endpoint of each one-second interval. By using the left endpoint Riemann sum as an approximation, you are assuming that the actual velocity is approximately constant on each one-second interval (or, equivalently, that the actual acceleration is approximately zero on each one-second interval), and that the velocity and acceleration have discontinuous jumps every second. This assumption is probably incorrect because it is likely that the velocity and acceleration change continuously over time. However, you decide to use this approximation anyway since it seems like a reasonable approximation to the actual velocity given the limited amount of data.
(A) Using the left endpoint Riemann sum, find approximately how far the object traveled.
Total displacement=
Total distance travelled=
27f90e83513fa118aa8656e06a548db639af4d79
Δx = (b - a)/ n
displacement = Xf- Xo
distance = velocity ⋅ time
None yet[/B]
*First image
Total displacement=
Δx = (b - a)/ n
None yet[/B]
What is stopping you from just completing the calculation? You have all the ##\Delta x## and ##y_i## values, and you have a formula for the answer.
BTW: the formula should read as ##S = \sum_i y_i (x_i - x_{i-1})##; that is, you should have ##y_i## and not ##f(y_i)## in the sum.
Likes scottdave
You could have ##y_i## or ##f(x_i)## in the sum, but not, as Ray said, ##f(y_i)##.
Related to How can I find this displacement?
1. How do I calculate displacement?
Displacement is calculated by subtracting the initial position from the final position.
2. What is the formula for displacement?
The formula for displacement is Δx = xf - xi, where Δx represents displacement, xf represents final position, and xi represents initial position.
3. What units are used for displacement?
Displacement is typically measured in units of length, such as meters (m) or centimeters (cm).
4. Can displacement be negative?
Yes, displacement can be negative if the final position is less than the initial position. This indicates that the object has moved in the opposite direction of its initial position.
5. How does displacement differ from distance?
Displacement is a vector quantity that takes into account the direction of an object's motion, while distance is a scalar quantity that only measures the total length traveled by an object regardless of direction.
17K
  • Classical Physics
  • Classical Physics
