Carlton Brown
- 3
Hello there. i would like to request some help please in the design of my meditation pyramid. If you can help me out i'd be greatly appreciative thank you.
I would like to set up an 8 hertz oscillating magnetic cycle around the pyramid. Why? because i wish to entrain higher alpha brainwave voltages while i meditate, in lieu of waiting for the solstices and equinoxes, as part of my Ritual Meditation method for accessing altered states of consciousness i.e. dissolving ego consciousness. Switches in states of consciousness have many physiological parameters, and reaching voltage thresholds for alpha brainwave output is crucial in this process. Meditation naturally powers up our alpha brainwaves, and these can be supplemented via entrainment i.e. external magnetic / electromagnetic signals of the same frequency (8 hertz). Numerous clinical studies have demonstrated this and you can review some scientific articles via << Spam link deleted by Moderators >> to know more if you wish.
The basic plan involves building a pyramid in proportion to Giza (1.75m H * 2.74m base, 51.85 degree angles) in my basement. i am located in a volcano caldera (Lake Atitlan) which represents a region of relatively high geomagnetic activity, and my house sits in front of 3 big volcanoes across a lake and over a major fault line. This pyramid will be magnetically aligned and will be constructed from steel reinforcing bars (>1 - 1.25" thick) which i was planning on earthing into the ground below the concrete floor. I would like to turn this pyramid into an electromagnet and achieve a magnetic field oscillating at 8 hertz. Guatemala uses AC 120V/60 hz. The initial plan was to wrap thinly insulated copper wire around the iron bars in anticipation that this technical challenge can be solved cost-effectively! i would also place a iron plate under my feet in the center. There is various literature indicating i should use a copper capstone/sphere. the pyramid will then be covered or walled with sand bags to help increase the sound proofing. i also need sensory silence to leave my mind!
kind regards
Carlton Brown
- Is it possible to create a 8 Hz AC current from the 120V/60 hertz power to flow through this electromagnet and set up 8 Hz oscillating magnetic fields?
- How would i go about achieving this cost-effectively please?
- What voltage/current would you recommend as my output?
- Does anyone have any further suggestions/inputs to the pyramid's design?
- Do you have any suggestions on earthing of the base and its contact with the floor for best effect?
kind regards
Carlton Brown
