How can I ignore information in my wave function?
In summary, the conversation discusses a wavefunction with a spatial part and a spin degree of freedom and the possibility of extracting a purely spatial wavefunction that gives the same predictions for observables that only depend on spatial variables. Possible approaches include using the Schrodinger or Heisenberg picture, the "propagator" operator, or constructing a reduced density matrix for the spatial part. However, it is noted that the original wavefunction may still be needed for measurements that affect the spin.
nonequilibrium
1,439
Hello,
Say I have a system with a spatial part and a spin degree of freedom, hence the wavefunction generally looks like [itex]\psi_+(\textbf r) |+\rangle + \psi_-(\textbf r) |- \rangle[/itex] w.r.t. for example the z-axis.
Now what if I'm simply interested in the spatial part? Can I perform an operation on this wavefunction such that I get a new wavefunction that is only spatial, but gives the same predictions for any observable that only depends on space variables? (e.g. [itex]L_z[/itex])
I feel this must be possible, and that it shouldn't even be hard, but I can't seem to think of the appriopriate operation right away and I also can't google it because I don't know what such an operation would be called.
I'm probably way off here, but oh well...
Doesn't this depend on if you are considering the Schrodinger picture or the Heisenberg picture?
If it is the former then H is time-independent, in the latter it is time-dependent. The time- dependence or independence of H will transfer to the time- dependence or independence of the observables.
It sounds like you are talking about the Schrodinger picture.
Also, you might want to look up the "propagator" which is probably the operator you are after.
Hm, I'm indeed talking about the Schrödinger picture, although I'm not sure how it would change matters, but then again I'm not too familiar with the Heisenberg picture, so yes for my answer one can restrict himself to the Schrödinger picture.
Well those things aside, would just dividing by the time part of your wavefunction give your new desired wavefunction? Or do you want a single operator which does it for all wavefunctions?
The time part of my wavefunction? I'm afraid you have misunderstood my question.
I'm looking for a (mathematical) way to erase the spin information in [itex]\psi_+(\textbf r) |+\rangle + \psi_-(\textbf r) |- \rangle[/itex] to get a purely spatial wavefunction. This is not time-related. It would be the wave function I would see if I had never heard of spin.
More practical, it would be useful if I were asked the mean position of the particle, or if I were asked the possible outcomes of a L_z measurement, I would just have to decompose this new spatial wavefunction into eigenfunctions of L_z and etc via the usual method.
Ok I probably can't help you. I thought spin is basically the same as angular momentum but just the ones with l = half-integer values??
Your wavefunction has two "spatial parts": ψ+(r) if the spin is up and ψ-(r) if the spin is down. If you want to ignore the spin you can't get a wavefunction, the best you can do is a probability, |ψ|2 = |ψ+|2 + |ψ-|2.
I would think the answer would be Aψ+(r) +B ψ-(r) where A and B are constants which keep normalization. I think this wavefunction will predict the same results as the original wave function, as long as no spin-detecting measurements were made.
If you want to describe measurements which don't affect the spin, I think you can use a reduced density matrix for the spatial part.
In basis-independent form, your state is |ψ+>⊗|+> + |ψ->⊗|->. The general approach would be to construct the full density matrix from that and trace over the spin. Then you get the reduced density matrix for the spatial part ρspatial, which can be used to calculate every relevant quantity for measurements which affect only the spatial part. These are of the type A⊗1. Expectation values can then be calculated by <A>=tr{Aρspatial}.
In your initial post, your state is given in the position basis. It is not immediately clear to me, how all of this looks in this "half" basis-dependent form, but this is probably just a technical thing.
If you want to do a simple position measurement, I agree with Bill. I think you have to add probabilities here, not probability amplitudes.
FAQ: How can I ignore information in my wave function?
Can I completely ignore certain information in my wave function?
It is not recommended to completely ignore any information in your wave function. Doing so may result in inaccurate or incomplete results. It is important to carefully consider and analyze all information in your wave function to ensure accurate outcomes.
How can I determine which information in my wave function is relevant and which can be ignored?
Determining the relevance of information in your wave function requires a thorough understanding of the variables and factors involved in the specific system or experiment. It may also involve consulting with other experts or conducting further research to ensure all relevant information is included in the wave function.
Is it possible to selectively ignore certain information in my wave function?
In some cases, it may be possible to selectively ignore certain information in your wave function. This can be done by assigning different weights or probabilities to different elements in the wave function. However, it is important to carefully consider the potential consequences of ignoring any information and to ensure that the overall integrity of the wave function is maintained.
Are there any techniques or strategies for effectively ignoring information in my wave function?
There are various techniques and strategies that can be used to effectively ignore information in a wave function. Some examples include applying statistical filters, using approximations, or simplifying the wave function by eliminating unnecessary variables. However, it is important to carefully evaluate the impact of these techniques on the overall accuracy of the wave function.
What are the potential drawbacks of ignoring information in my wave function?
The primary drawback of ignoring information in a wave function is that it may lead to inaccurate or incomplete results. This can have significant consequences, especially in scientific research or applications where precision and accuracy are critical. Additionally, ignoring information may also limit the potential for new discoveries and advancements in the field.
