How can I implement a multi-task deep learning neural network?
The discussion revolves around designing a neural network for a multi-task learning problem involving a 5-character string pattern represented by 6 features and one-hot encoded into 15 elements. The user encounters an error when trying to concatenate the one-hot encoded outputs, indicating a shape mismatch. The proposed network architecture includes two hidden layers and six output layers, each corresponding to one of the characters in the string, with softmax activation for classification into three classes. Suggestions for resolving the issue include reviewing existing examples of similar machine learning problems and studying resources such as "Hands-On Machine Learning with Scikit-Learn, Keras, and TensorFlow" by Aurélien Géron, as well as free online books and video tutorials on neural networks. The emphasis is on gaining a deeper understanding of machine learning principles to effectively design and troubleshoot the neural network.
user366312
TL;DR Summary
I have 3 classes (A, B, and C). I have 6 features.
These features represent a 5-character string pattern comprising of 3-classes(e.g. AABBC, etc.). So, that means, features are not directly dependent on classes.
Hence, I am confused about the solution.
I have 6 features:
[CODE title="features"]train_x = [[ 6.442 6.338 7.027 8.789 10.009 12.566]
[ 6.338 7.027 5.338 10.009 8.122 11.217]
[ 7.027 5.338 5.335 8.122 5.537 6.408]
[ 5.338 5.335 5.659 5.537 5.241 7.043]][/CODE]
Let, a 5-character string pattern is one-hot encoded as follows:
[CODE title="one_hot_encoding"]train_z = [[0. 0. 1. 0. 0. 1. 0. 0. 1. 0. 0. 1. 1. 0. 0.]
[0. 0. 1. 0. 0. 1. 0. 0. 1. 1. 0. 0. 1. 0. 0.]
[0. 0. 1. 0. 0. 1. 1. 0. 0. 1. 0. 0. 1. 0. 0.]
[0. 0. 1. 1. 0. 0. 1. 0. 0. 1. 0. 0. 0. 0. 1.]][/CODE]
So, I think this is a Multi-task learning problem.
[CODE lang="python" title="source_code"] # there would be 6 inputs for 6 features
inputs_tensor = keras.Input(shape=(FEATURES_COUNT,))
# there would be 2 hidden layers
hidden_layer_1 = keras.layers.Dense(LAYER_1_NEURON_COUNT, activation="relu")
hidden_layer_2 = keras.layers.Dense(LAYER_2_NEURON_COUNT, activation="relu")
# there would be 5 outputs for 5-characters
# each o/p layer will have 3 neurons for 3 classes
output_layer_1 = keras.layers.Dense(CLASSES_COUNT, activation='softmax') # 3 neuraons for 3 classes
output_layer_2 = keras.layers.Dense(CLASSES_COUNT, activation='softmax') # -do-
output_layer_3 = keras.layers.Dense(CLASSES_COUNT, activation='softmax') # -do-
output_layer_4 = keras.layers.Dense(CLASSES_COUNT, activation='softmax') # -do-
output_layer_5 = keras.layers.Dense(CLASSES_COUNT, activation='softmax') # -do-
output_layer_6 = keras.layers.Dense(CLASSES_COUNT, activation='softmax') # -do-
# assembling the layers.
x = hidden_layer_1(inputs_tensor)
x = hidden_layer_2(x)
# configuring the output
output1 = output_layer_1(x)
output2 = output_layer_2(x)
output3 = output_layer_3(x)
output4 = output_layer_4(x)
output5 = output_layer_5(x)
model = keras.Model(inputs=[inputs_tensor],
outputs=[output1, output2, output3, output4, output5],
name="functional_model")
# model.summary()
opt_function = keras.optimizers.SGD(lr=0.01, decay=1e-1, momentum=0.9, nesterov=True)
model.compile(loss='categorical_crossentropy',
optimizer=opt_function,
metrics=['accuracy'])
model.fit(
tx, tz,
epochs=EPOCHS,
batch_size=BATCH_SIZE
)[/CODE]
In the above source code, I am passing a 5-character string pattern as a 15-digit one-hot-encoded to be used as classes.
And, this is the dilemma for me.
Naturally, this is not working:
[CODE title="error"]C:\ProgramData\Miniconda3\envs\by_nn\python.exe C:/Users/pc/source/repos/OneHotEncodingLayer__test/by_nn_k____5_outputs.py
using 2 points for training and 3 for validation
Traceback (most recent call last):
File "C:/Users/pc/source/repos/OneHotEncodingLayer__test/by_nn_k____5_outputs.py", line 63, in <module>
tz = tf.concat([tf.constant(d, shape=(1, CLASSES_COUNT), dtype=np.float32) for d in train_z], 0)
File "C:/Users/pc/source/repos/OneHotEncodingLayer__test/by_nn_k____5_outputs.py", line 63, in <listcomp>
File "C:\ProgramData\Miniconda3\envs\by_nn\lib\site-packages\tensorflow\python\framework\constant_op.py", line 263, in constant
return _constant_impl(value, dtype, shape, name, verify_shape=False,
File "C:\ProgramData\Miniconda3\envs\by_nn\lib\site-packages\tensorflow\python\framework\constant_op.py", line 275, in _constant_impl
return _constant_eager_impl(ctx, value, dtype, shape, verify_shape)
File "C:\ProgramData\Miniconda3\envs\by_nn\lib\site-packages\tensorflow\python\framework\constant_op.py", line 322, in _constant_eager_impl
raise TypeError("Eager execution of tf.constant with unsupported shape "
TypeError: Eager execution of tf.constant with unsupported shape (value has 15 elements, shape is (1, 3) with 3 elements).
Process finished with exit code 1[/CODE]
How can I properly design my neural network?
Technology news on Phys.org
Your question is very broad and unlikely to get any meaningful response On PF. My suggestion is to look for examples of this class of ML problems and see how these folks solved it.
in the end, you are going to need a course / book on ML and it’s practices to solve your problem.
Take a look at Geron’s book: Hands on ML with ScikitLearn, Keras and Tensorflow 2nd edition.
https://www.amazon.com/dp/1492032646/?tag=pfamazon01-20
Neural Networks and Deep Learning is an excellent free online book by Michael Neilson. You can also find free online copies of the source code for everything discussed in the book.
http://neuralnetworksanddeeplearning.com/
There is also the 100 page Machine Learning book by Burkiv that is a try and buy license if search a bit vs buy it on Amazon.
In addition 3brown1blue of YouTube fame has a sequence of videos on understanding Neural Nets.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
