How Can I Motorize a Lazy Susan to Rotate at 20-30 RPM?
  • Thread starter konaandcooper
In summary, the lazy susan idea is not feasible because it would not be able to support the weight of the item it rests on and the fan tilted solution is not feasible either because it spins too fast and would not be able to hold the weight of the object for an extended period of time.
konaandcooper
I know this is a weird question but hey...here it goes. I assume everybody here knows what a "lazy susan" is. I want to find a way to power a "lazy susan" (or something along those lines) so that it revolves at a rate of approximately 20 -30 rpm.
I have an item that needs to rest on the lazy susan which weighs approximately 7 pounds. I originally thought about using an old record player because I knew I could get the RPMs to hold at 33 rpms. The rate of the Rpms can fluctuate.
The record player idea just isn't going to work. I then thought of using a fan which tilts 90 degrees and gluing a plate to the top, but it spins way to fast and cannot really support 7 pounds for an extended period time.
Does anybody here have an idea as to how I might accomplish this task?
Thanks in advance guys.
Welcome to the PF.
Is the 7 pound object centered on the axis of rotation, or is it out near the edge of the plate? Why did the record player not work?
It will be centered. As far as the record player not working...it probably would have, but that solution has been taken off of the table for reasons which would take too long to explain.
FAQ: How Can I Motorize a Lazy Susan to Rotate at 20-30 RPM?
How can I find a solution to my problem?
To find a solution to your problem, it is important to first clearly identify and define the problem. Then, you can research and gather information about the problem and potential solutions. Additionally, seeking advice or guidance from experts or individuals who have experience with similar problems can also be helpful in finding a solution.
What are some steps I can take to solve my problem?
Some steps you can take to solve a problem include brainstorming and generating ideas, evaluating and analyzing the potential solutions, and implementing and testing the chosen solution. It can also be helpful to break down the problem into smaller, more manageable tasks and to seek input and feedback from others.
How do I know if a solution is effective?
A solution can be considered effective if it successfully addresses and resolves the problem at hand. This can be determined by evaluating the outcomes and results of implementing the solution. It is important to also consider any potential drawbacks or limitations of the solution.
How can I come up with creative solutions to my problem?
To come up with creative solutions, it can be helpful to approach the problem from different perspectives and to think outside the box. Collaborating with others and seeking inspiration from different sources can also spark new and innovative ideas. Additionally, practicing creativity and being open to new and unconventional ideas can also aid in finding creative solutions.
What should I do if my initial solution does not work?
If your initial solution does not work, do not get discouraged. It is important to reassess and analyze the problem and potential solutions. You may need to modify or adjust your initial solution, or try a completely different approach. Seeking feedback and input from others can also help in finding a more effective solution.
