C/C++ How can I overload the + operator in C++ for a family vacation program?
  • Thread starter Thread starter sxal96
    C++ Operator
The discussion centers around implementing operator overloading for the `+` operator in a `FamilyVacation` class, specifically to add days to a vacation while retaining the number of people. The user initially struggles with their implementation, which incorrectly modifies a parameter instead of the class attributes and fails to return a new instance of `FamilyVacation`. Key points include the need to create a new instance to hold the modified values and properly copy the `numPeople` attribute from the original object. Suggestions emphasize that the overloaded operator function must return a `FamilyVacation` object, initialized with the correct number of days and copied number of people. The user is guided to declare a `result` object, set its properties, and return it, clarifying that simply modifying input parameters does not achieve the desired outcome.
sxal96
Hi, I'm having difficulty with this program in a textbook. The instructions are as follows:
Overload the + operator as indicated. Sample output for the given program:
First vacation: Days: 7, People: 3
Second vacation: Days: 12, People: 3
This is the code that follows
Code:
#include <iostream>
using namespace std;
class FamilyVacation{
   public:
      void  SetNumDays(int dayCount);
      void  SetNumPeople(int peopleCount);
      void  Print() const;
      FamilyVacation operator+(int moreDays);
   private:
      int   numDays;
      int   numPeople;
void FamilyVacation::SetNumDays(int dayCount) {
   numDays = dayCount;
   return;
void FamilyVacation::SetNumPeople(int peopleCount) {
   numPeople = peopleCount;
   return;
// FIXME: Overload + operator so can write newVacation = oldVacation + 5,
//        which adds 5 to numDays, while just copying numPeople.
/* Your solution goes here  */
void FamilyVacation::Print() const {
   cout << "Days: " << numDays << ", People: " << numPeople << endl;
   return;
int main() {
   FamilyVacation firstVacation;
   FamilyVacation secondVacation;
   cout << "First vacation: ";
   firstVacation.SetNumDays(7);
   firstVacation.SetNumPeople(3);
   firstVacation.Print();
   cout << "Second vacation: ";
   secondVacation = firstVacation + 5;
   secondVacation.Print();
   return 0;
I have to put my solution directly underneath where it asks for it, so I tried this but it sets the "People" value in the second vacation to 0.
Code:
FamilyVacation FamilyVacation::operator+(int moreDays){
   moreDays = numDays + 5;
Idk what to do so that the number of people doesn't change when I update numDays. Also, if I use anything involving "return" at the very end, it leads to an error. Any help/guidance would be appreciated.
Technology news on Phys.org
Hi moofasa! Welcome to MHB! (Smile)
The FIXME comment says: "which adds 5 to numDays, while just copying numPeople."
However, in your solution 'numDays' is not changed. Instead 'moreDays' gets changed. But that's only a parameter that gets discarded afterwards.
Furthermore, 'numPeople' is not copied. (Worried)
Thank you!
How would I copy numPeople? Anytime I try incorporating 'numPeople' into my solution, I get an error saying that numPeople isn't declared or that it could not be converted.
We need a new instance of FamilyVacation that we initialize with the proper values.
We can do that by declaring [m]FamilyVacation result;[/m], initializing it, and returning it at the end.
I don't really understand operator overloading at all but this is my attempt that led to an error
Code:
class FamilyVacation result{
   public:
      void result(int peopleCount, numPeople);
   private:
void FamilyVacation FamilyVacation::result(int peopleCount, int numPeople){
   peopleCount = numPeople;
   return;
Code:
Consider the function [m]FamilyVacation FamilyVacation::operator+(int moreDays)[/m].
It has 'moreDays' as input.
Changing that input won't have any effect.
More importantly, the function is supposed to return a [m]FamilyVacation[/m].
As it is now, it's not returning anything, which is already an error condition.
It should be something like:
Code:
   return result;
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
