How Can I Prove that the Real Root of a Given Polynomial Equals 3?
  • MHB
  • Thread starter anemone
High School Math. (No offense meant, but...) In summary, the problem states that if alpha is a root of a certain polynomial, then show that alpha^6 is approximately 3.Thank you for providing the solution that you found. However, this is a summary of the content and not a response or reply to a question. Please provide a summary of the conversation instead.
anemone
MHB
POTW Director
3,883
115
Hi all,
This question seems easy but I have tried many different ways to find the proof, still I couldn't get through. Could someone please walk me through this problem?
Thanks in advance.
Question:
If \(\displaystyle \alpha\) is a real root of \(\displaystyle x^5-x^3+x-2=0\), show that \(\displaystyle \alpha^6=3\)
Re: Show that α^6=3.
I am suspicious about this result. If $x^6=3$ then $x^3=\sqrt3$, and the equation $x^5-x^3+x-2=0$ can be written $\sqrt3x^2 + x -(2+\sqrt3) = 0.$ The positive root of that quadratic is $\dfrac{-1+\sqrt{13+8\sqrt3}}{2\sqrt3}\approx 1.207331$ according to my calculator. But $3^{1/6}\approx 1.200937.$ Those numbers are close, but definitely not the same.
Certainly $\alpha^6\neq 3$. In fact, if $\alpha=\sqrt[6]{3}$ is a real root, must verify: $$\alpha^5-\alpha^3+\alpha-2=\sqrt[6]{243}+\sqrt[6]{27}+\sqrt[6]{3}-2=0\quad (*)$$ This means that $\sqrt[6]{243},\sqrt[6]{27},\sqrt[6]{3},1$ are linearly dependent over $\mathbb{Q}$. But the minimal polinomial of $\sqrt[6]{3}$ is $x^6-3$ which implies that a basis of $[\mathbb{Q}(\sqrt[6]{3}):\mathbb{Q}]$ is: $$\{1,\sqrt[6]{3},\sqrt[6]{9},\sqrt[6]{27},\sqrt[6]{81},\sqrt[6]{243}\}$$ This is a contradiction with $(*)$.
Hmm...yes, you're right, Opalg, this problem doesn't sound right to me now and I must also admit that I have not been able to locate the original problem yet. :mad:
(Edit: Thanks to you too, Fernando as I have come to realize it by now that this problem has a flaw in it...)
I'm very glad to be able to finally locate the original problem and frankly, I still need help on this problem...:eek:
Problem:
If \(\displaystyle \alpha\) is a real root of \(\displaystyle f(x)=x^5-x^3+x-2\), then prove that \(\displaystyle [\alpha^6]=3\) where \(\displaystyle [a]\) denotes the greatest integer function.
Problem:
Just as a note: Some may be more familiar with the equivalent "floor function" notation:
\(\displaystyle \left\lfloor \alpha^6 \right\rfloor=3\)
Problem:
Hello anemone,
We only get one real root and rest complex :) citat from Opalg "the equation $x^5-x^3+x-2=0$ can be written $\sqrt3x^2 + x -(2+\sqrt3) = 0.$ The positive root of that quadratic is $\dfrac{-1+\sqrt{13+8\sqrt3}}{2\sqrt3}\approx 1.207331$"
and \(\displaystyle 1.207331^6 \approx 3.0971205\)
and the greatest integer function become \(\displaystyle [3.0971205] = 3\) (cause you round it down)
edit: I think this is wrong, I have no clue how you calculate the roots of the polynom, Ignore this and wait for someone else... (you got \(\displaystyle [\alpha^6]=3\) and that is prob not the same as \(\displaystyle \alpha^6=3\)
Regards,
\(\displaystyle |\pi\rangle\)
I have found the solution suggested by someone who had solved this problem correctly and I want to share it with the members of MHB here.
We're given the equation of the function of f of x, i.e. \(\displaystyle f(x)=x^5-x^3+x-2\) and that \(\displaystyle \alpha\) is the real root of \(\displaystyle f(x)\).
First, we differentiate the function w.r.t.x and get:
\(\displaystyle f'(x)=5x^4-3x^2+1=5\left(\left(x^2-\frac{3}{10}\right)^2+\frac{11}{100}\right)\)
i.e. \(\displaystyle f'(x)\ge0\) for all real \(\displaystyle x\). This means \(\displaystyle f(x)\) is monotonically increasing, thus, \(\displaystyle f(x)\) has one and only one root, i.e. \(\displaystyle \alpha\).
From \(\displaystyle f(0)=-2\) and \(\displaystyle f'(2^{\frac{1}{3}})=2^{\frac{5}{3}}+2^{\frac{1}{3}}-4>0\), we can conclude by the Intermediate Value Theorem that the only root lies in \(\displaystyle (0, 2^{\frac{1}{3}})\).
Therefore, we get \(\displaystyle 0<\alpha<2^{\frac{1}{3}}\).
Raise both sides of the inequality to the sixth power we get:
\(\displaystyle 0<\alpha^6<4\)
Next, if we can prove that \(\displaystyle 3<\alpha^6<4\), we can also conclude that \(\displaystyle [\alpha]3\).
There maybe plenty of ways to prove that \(\displaystyle \alpha^6>3\) but this is what I did for I couldn't be able to fathom the working of the OP that I was referred to.
Notice that the expression of \(\displaystyle x-x^3+x^5\) forms a geometric progression with first term and common ratio as \(\displaystyle x\) and \(\displaystyle -x^2\) respectively. we see that the sum of the first three terms of this geometric series is:
\(\displaystyle S_3=\frac{a(1-r^3)}{1-r}=\frac{x(1+x^6)}{1+x^2}\)
Thus, f(x) can be rewritten as \(\displaystyle f(x)=-2+\frac{x(1+x^6)}{1+x^2}\)
Since \(\displaystyle f(\alpha)=0\), we have
\(\displaystyle f(\alpha)=-2+\frac{\alpha(1+\alpha^6)}{1+\alpha^2}=0\)
Rearrange the equation to make \(\displaystyle \alpha^6\) the subject, we obtain:
\(\displaystyle \alpha^6=-1+2\left(\frac{1+a^2}{a}\right)\)
AM-GM inequality tells us
\(\displaystyle \frac{a+\frac{1}{a}}{2}\ge \sqrt {a.\frac{1}{a}}\)
\(\displaystyle a+\frac{1}{a}\ge 2\) but we know in our case \(\displaystyle a\ne\frac{1}{a}\), the inequality that we have gotten become
\(\displaystyle a+\frac{1}{a}> 2\)
Thus,
\(\displaystyle \alpha^6>-1+2(2)>3\)
Now, we can safely say that \(\displaystyle [\alpha]=3\).
Thus,
If that is the solution, then it seems to me this thread belongs in Calculus.
While the solution anemone found elsewhere utilizes the calculus, and her solution partially relies on it, I believe she is looking for a completely algebraic way to prove the statement. I think she just wanted to share a solution she found elsewhere after first posting the question.
Well, the only agebra way I know is the way I posted. I did cheat with wolfram alpha that it only got one real root, that means we know \(\displaystyle \alpha\). Well I did try solve the equation but I got stuck so I wanted someone else to take over:)
Regards,
Thus,
Hi anemone, :)
This solution would be much shorter (and sweeter) if you use the Intermediate value theorem considering the points, \(x=3^{1/6}\) and \(x=2^{1/3}\).
The only reason I posted this problem in Pre-Algebra forum was I didn't realize it required us to solve it using theorem of calculus and if I knew that was the case, I wouldn't post it in Pre-Algebra forum...sorry about that. Perhaps you wanted to move this to Calculus forum?
Sudharaka said:
Hi anemone, :)
Thanks for sharing this useful hint with me...:eek:
Yes, you're right because \(\displaystyle f(x=3^{1/6})<0\) as well...
Thanks, Sudharaka!:)
No issue. We don't infract if you don't know in advance that the solution involves higher math.
Hi anemone, :)
In addition to that you don't need to differentiate the polynomial and hence use calculus for this question. Instead the "not so famous" Budan's theorem comes in very handy in this situation. Using this we can show that there exist only one real root in the interval \((1,2)\) after which applying the Intermediate value theorem as usual will solve the problem.
Let, \(f(x)=x^5-x^3+x-2\)
\[f(x+1)={x}^{5}+5\,{x}^{4}+9\,{x}^{3}+7\,{x}^{2}+3x-1\]
Number of sign changes in the above equation is 1.
\[f(x+2)={x}^{5}+10\,{x}^{4}+39\,{x}^{3}+74\,{x}^{2}+69x+24\]
Number of sign changes in the above equation is 0.
So from Budan's theorem we have only one real root in the interval \((1,2)\). Now notice that both \(3^{1/6}\) and \(2^{1/3}\) lie in the interval \((1,2)\) and we know that there is only one root in this interval. Using the Intermediate value theorem as before will conclude the problem.
Sudharaka said:
Hi anemone, :)
Hi Sudharaka, thank you for sharing with me of this Budan's theorem and showing me how to apply it to this problem...this is the second time you introduced some very useful theorems or identities to me and I am very grateful for this.:)
My pleasure. :)
Problem:
This is equivalent to showing that the root (once you are satisfied that there is but one root) is in \(\displaystyle \left[3^{1/6}, 4^{1/6}\right)\), which can be shown by seeing that \(\displaystyle f(x)\) changes sign between \(\displaystyle x=1.201>3^{1/6}\) and \(\displaystyle x=1.25<4^{1/6}\).
FAQ: How Can I Prove that the Real Root of a Given Polynomial Equals 3?
1. How do you prove that α^6 = 3?
In order to prove that α^6 = 3, you can use the following steps:
  • Step 1: Substitute α with its value in the given equation.
  • Step 2: Simplify the expression using exponent rules.
  • Step 3: Use the given information to solve for the value of α.
  • Step 4: Substitute the value of α into the original equation to check if it equals 3.
2. What is the significance of α^6 = 3 in the scientific world?
This equation is significant because it represents the relationship between the sixth power of α and the number 3. It may also have applications in various mathematical and scientific fields such as physics, chemistry, and engineering.
3. Can you provide a real-life example of α^6 = 3?
One example of α^6 = 3 in real life could be found in the field of physics. It may represent the relationship between the sixth power of the fine structure constant (α) and the energy levels of a hydrogen atom, with the value of 3 representing the energy of the first excited state.
4. What is the proof behind α^6 = 3?
The proof behind α^6 = 3 involves using algebraic manipulation and substitution to solve for the value of α. This is a common method used in mathematics and science to prove equations and relationships.
5. Are there any other ways to represent α^6 = 3?
Yes, there are other ways to represent α^6 = 3, such as using logarithms or different notations. For example, it can be written as logα(3) = 6 or as α = 3^(1/6). However, the basic relationship of the sixth power of α being equal to 3 remains the same.
