MHB How can I prove the rank of a matrix with a specific pattern of entries?
  • Thread starter Thread starter A.Magnus
    Matrix rank
A.Magnus
I would love to get help on this problem: Suppose that $M$ is a square $k \times k$ matrix with entries of 1's in the main diagonal and entries of $\frac{1}{k}$ for all others. Show that the rank of $M$ is $k$.
I think I should go about by contradiction, that is, by assuming that the column vectors are not linearly independent. Since there are $k$ number of column vectors, then hopefully I can show that the rank of $M$ is indeed $k$. Unfortunately I don't know how to put these ideas down in writing; your time and gracious helps are therefore very much appreciated. Thank you - MA
I think I should go about by contradiction, that is, by assuming that the column vectors are not linearly independent. Since there are $k$ number of column vectors, then hopefully I can show that the rank of $M$ is indeed $k$. Unfortunately I don't know how to put these ideas down in writing; your time and gracious helps are therefore very much appreciated. Thank you.
Hi MaryAnn! Welcome to MHB! ;)
Suppose we add all column vectors together and divide by $1+\frac{k-1}k$, then we get:
$$\begin{bmatrix}1\\ 1\\ \vdots \\ 1\end{bmatrix}$$
Now subtract $k$ times the first column vector:
- k\begin{bmatrix}1\\ 1/k\\ \vdots \\ 1/k\end{bmatrix}
=\begin{bmatrix}1-k\\ 0\\ \vdots \\ 0\end{bmatrix}
Hey! That's a multiple of a standard unit vector!
Moreover, we can get each unit vector from a linear combination of the column vectors.
Therefore the column vectors are independent.
Thank you for your gracious help! This is more than just a genius' solution. - MA
The world of 2\times 2 complex matrices is very colorful. They form a Banach-algebra, they act on spinors, they contain the quaternions, SU(2), su(2), SL(2,\mathbb C), sl(2,\mathbb C). Furthermore, with the determinant as Euclidean or pseudo-Euclidean norm, isu(2) is a 3-dimensional Euclidean space, \mathbb RI\oplus isu(2) is a Minkowski space with signature (1,3), i\mathbb RI\oplus su(2) is a Minkowski space with signature (3,1), SU(2) is the double cover of SO(3), sl(2,\mathbb C) is the...
