MarkFL
MHB
- 13,288
- 12
You are a gunner stationed on a distant outpost located on a desolate planet with no atmosphere. When you signed up for duty, you envisioned traveling the galaxy and seeing many wondrous things. Your recruiter painted quite an exciting picture, regaling you with many fascinating stories of his time in deep space! You think of the irony as you stare at the walls of your sparsely decorated dorm room day after day, each of which lasts roughly 3 Earth weeks on this stupid planet. (Dull)
But, this planet is rich in minerals that mankind wishes to mine, and so here you are. However, another race of beings also wants to mine this planet, and so naturally we are at war, as the universe is simply too small to share. (Punch)
Your gun is underground, but can maneuver such that its muzzle is at ground level for any launch angle $0<\theta<\dfrac{\pi}{2}$, and the terrain is flat all around your location. Your gun has a muzzle velocity of $v_0$ and the acceleration due to gravity is $g$.
Suddenly your boredom is shattered as an enemy craft has just unwittingly landed within the maximum range of your gun. If $r_{\max}$ is the maximum range of your gun, then let the range of the enemy be $k\cdot r_{\max}$, where $0<k<1$. It has been determined that the EM shielding of the enemy craft is capable of withstanding being hit by one of your projectiles, however, if hit by two projectiles simultaneously, the shield will collapse and the enemy will be destroyed. If you fail, your location will have been given away, and the enemy will begin firing on your location. If you take too long, the enemy will also inevitably discover your location and begin firing. Thus, you need to quickly and correctly determine:
a) The two launch angles for the projectiles.
b) How long after the first projectile is fired should the second be fired?
