Nikhil N
- 81
- 2
I have a python script for which the input data are coming from Matlab. I have tried to use pymatlab, but it is failing. Can anyone suggest any other method?
To import values from Matlab into Python, you can use the matlab.engine
module. This module allows you to create a connection between Matlab and Python, and you can then use the matlab.engine
functions to retrieve the values from your Matlab workspace.
matlab.engine
module and the scipy.io
module to import values?The matlab.engine
module provides a direct connection between Matlab and Python, allowing you to retrieve values from your Matlab workspace in real-time. The scipy.io
module, on the other hand, allows you to import and export data from a variety of file formats, including Matlab files. It does not provide a direct connection to Matlab.
Yes, you can pass variables from Python to Matlab using the matlab.engine
module. You can use the matlab.engine
functions to create variables in your Matlab workspace and then use them in your Matlab code.
matlab.engine
module?You can use the try
and except
statements in your Python code to handle errors that may occur when using the matlab.engine
module. You can also use the matlab.engine
function isMATLABRunning()
to check if Matlab is currently running and handle errors accordingly.
matlab.engine
module with any version of Matlab?The matlab.engine
module is only compatible with Matlab versions R2014b or later. If you are using an earlier version of Matlab, you can use the scipy.io
module to import and export data from your Matlab files.
