hello_one
- 4
I plan to design a steer by wire system,is there a formula to caculate the motor torque?and how can i select a proper ECU.
regards.
regards.
Talk to the people at SKF ...?hello_one said:I plan to design a steer by wire system...how can i select a proper ECU.
oh,that is great helpful for me ,thanks.OCR said:
oh,i am sorry that i can't understand your implement exactly,i plan to do a steer by wire system include it's controller.I am also puzzled with the parameter.my purpose is realize the steer .russ_watters said:Have you looked at what parameters are available via the on-board data port?
You asked about motor torque. Are you aware that a car's Engine Control Unit provides data that you can read and may help find torque? Have you looked at what data is available?hello_one said:oh,i am sorry that i can't understand your implement exactly,i plan to do a steer by wire system include it's controller.I am also puzzled with the parameter.my purpose is realize the steer .
My work is select two motors(most of them are dc motor).one is the Steering reaction force actuator.the other is Steering actuator .And select a ecu to control these two motors to realize the steer work.I'm not familiar these works and puzzled for the whole work,especially the simulation.russ_watters said:You asked about motor torque. Are you aware that a car's Engine Control Unit provides data that you can read and may help find torque? Have you looked at what data is available?
[edit] Reading your question again, it isn't clear to me what "motor" you are referring to...car or steering system...
A steer-by-wire ECU (Electronic Control Unit) and motor are components used in a steer-by-wire system to control the steering of a vehicle electronically, rather than through a mechanical connection between the steering wheel and the wheels.
A steer-by-wire ECU and motor work together to receive signals from the steering wheel and sensors on the vehicle, and then use this information to control the steering of the vehicle. The ECU sends electronic signals to the motor, which adjusts the steering angle of the wheels accordingly.
When selecting a steer-by-wire ECU and motor, you should consider the compatibility with your vehicle make and model, the power and torque capabilities of the motor, the responsiveness and accuracy of the ECU, and the safety features and redundancies in case of system failure.
You can consult with a mechanic or automotive expert to determine if a steer-by-wire ECU and motor are suitable for your vehicle. They can assess the compatibility and make recommendations based on your specific vehicle and needs.
Yes, it is important to regularly check and maintain the wiring and connections of the ECU and motor to ensure proper functioning. If you experience any issues with your steer-by-wire system, it is best to consult with a professional for proper troubleshooting and repairs.
