MHB How can I show b^2 > 24c in a cubic with one maximum and one minimum?
The discussion centers on proving that for the cubic curve y = 8x^3 + bx^2 + cx + d, the condition b^2 > 24c holds true when there are two distinct points where the gradient is zero, indicating one maximum and one minimum. The gradient is represented by the derivative y' = 24x^2 + 2bx + c, which is a second-order polynomial. It is established that for two roots to exist, the discriminant must be greater than zero, leading to the inequality 4b^2 > 96c. The participant initially misinterpreted the coefficients but later clarified the correct relationship. The conclusion emphasizes the importance of understanding the discriminant in establishing the condition for the cubic function.
camrocker
Hello, been thinking on this one for a little while, and can't seem to figure it out. Problem statement is:
The cubic curve y = 8x^3 + bx^2 + cx + d has two distinct points P and Q, where the gradient is zero.
Show that b^2 > 24c.
It seems simple enough, but I can't logic it out. This equation has two distinct points where gradient is zero, so one maximum and one minimum, right? I played around with an online graphing calculator and saw that b^2 > 24c for two points of zero gradient is in fact true, but don't see how to mathematically prove/show this.
What direction should I be taking to show that b^2 > 24c? Thanks for any tips!
Mathematics news on Phys.org
The gradient of the curve $$y = 8x^3 + bx^2 + cx + d$$ is $$y' = 24x^2 + 2bx + c$$
Since it is a second order polynomial it has two roots when the discriminant $\Delta$ is $>0$.
$$\Delta>0 \Rightarrow 4b^2-4 \cdot 24 c>0 \Rightarrow 4b^2>4 \cdot 24c \Rightarrow b^2>24c$$
Thank you so much! I finally got to the discriminant point some time after posting this, but I tossed it aside because I forgot that b was 2b not just b, so I got b^2 > 96c. Thanks for the help!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
