How Can I Simplify This Linear Equation to a Quartic in q Using Maple?
In summary, to obtain a quartic in q from the given equation, you can use simplification and expansion techniques. Once you have the quartic, use Descarte's rule of signs to determine the number of positive roots. By substituting q=1-Q, you can also obtain a second quartic in Q and determine the number of steady states of q less than 1. It is recommended to use mathematical software like Maple to assist with the process.
ra_forever8
129
Using the maple I am trying to get quardic in q from this big linear equation. Then use Descarte’s rule of signs to determine the number of positive roots.
\begin{equation}
\frac{\gamma*q*P_Q}{k_p*(1-q)*P_C} = \frac{I*\alpha}{k_f+k_d+\frac{k_n*\lambda_b*\gamma*q*P_Q}{\lambda_b*\gamma*q*P_Q+k_p*\lambda_r*(1-q)^2}+k_p*(1-q)}
\end{equation}
Values of parameters are given below:
$I=1200$
$k_f = 6.7*10.^7$
$k_d = 6.03*10.^8$
$k_n = 2.92*10.^9$
$k_p = 4.94*10.^9$
$\alpha = 1.14437*10.^(-3)$
$\lambda_b = 0.87e-2$
$\lambda_r = 835$
$\gamma = 2.74$
$P_C = 3*10.^(11)$
$P_Q = 2.87*10.^(10)$
I tried the code in maple to get quartic in q but DOES NOT WORK.
Code:
         II := 1200:
k_f := 6.7*10.^7:
k_d := 6.03*10.^8:
k_n := 2.92*10.^9:
k_p := 4.94*10.^9:
alpha := 1.14437*10.^(-3):
lambda_b := 0.87e-2:
 lambda_r := 835:
 ggamma := 2.74:
 P_C := 3*10.^11:
P_Q := 2.87*10.^10:
         eq := ggamma*q*P_Q/(k_p*(1-q)*P_C) = II*alpha/(k_f+k_d+k_n*lambda_b*ggamma*q*P_Q/(lambda_b*ggamma*q*P_Q+k_p*lambda_r*(1-q)^2)+k_p*(1-q)):
simply(eq, q);
My lecturer want me to manipulate the equation and get a quartic in q before substituting the values of parameters into the equation. After that,use Descarte’s rule of signs to determine the number of positive roots. Then write Q=1-q to get second quartic in Q and repeat rule of signs to determine number of steady states of q less than 1. And do the substition of parameters if necessary.
Now, its kind of hard for me what he wants because to get quartic in q first from the equation is hard to do by hand , so i have to use in maple which is not working then use Descarte’s rule of signs.
Thank you for your post. I understand that you are struggling to manipulate the given equation and obtain a quartic in q. I would like to offer some suggestions that may help you in your task.
Firstly, it is important to understand that manipulating equations and obtaining specific forms can be challenging, especially when dealing with complex equations like the one provided. It is not uncommon for the process to take multiple steps and involve the use of mathematical software like Maple.
To begin, I suggest starting with the original equation and simplifying it as much as possible. This may involve combining terms, factoring, and using algebraic techniques. Once you have simplified the equation, you can start to manipulate it to obtain a quartic in q.
One approach you can take is to multiply both sides of the equation by the denominators and then expand the resulting expression. This will result in a quartic equation in q. You can then use Maple to solve for q and obtain the four roots.
Once you have the quartic in q, you can use Descarte's rule of signs to determine the number of positive roots. This rule states that the number of positive roots of a polynomial equation is either equal to the number of sign changes in the coefficients or less than that by an even number. For example, if the polynomial has three sign changes, then it can have either three or one positive roots.
After determining the number of positive roots, you can substitute q=1-Q and repeat the process to obtain a second quartic equation in Q. This will allow you to determine the number of steady states of q less than 1.
I hope this helps you with your task. Remember to take your time and use Maple or other mathematical software to assist you in the process. Good luck!
FAQ: How Can I Simplify This Linear Equation to a Quartic in q Using Maple?
What is a linear equation?
A linear equation is an algebraic equation in which each term is either a constant or a product of a constant and a single variable. The variable in a linear equation is typically represented by x. The general form of a linear equation is ax + b = 0, where a and b are constants.
What is a quartic equation?
A quartic equation is a polynomial equation of the fourth degree, meaning it contains terms with a maximum exponent of 4. The general form of a quartic equation is ax^4 + bx^3 + cx^2 + dx + e = 0, where a, b, c, d, and e are constants and a is not equal to 0.
How can Maple be used to simplify a linear equation to get a quartic in q?
Maple is a computer algebra system that can be used to perform mathematical computations and manipulations. To simplify a linear equation to get a quartic in q using Maple, you can use the "solve" function with the appropriate parameters. For example, the command "solve(eq, q)" where "eq" is the linear equation, will return the simplified quartic equation in q.
What is Descarte's rule of signs?
Descarte's rule of signs is a method used to determine the number of positive and negative real roots of a polynomial equation. It states that the number of positive roots is equal to the number of sign changes in the coefficients of the terms of the polynomial or less than this number by an even integer. Similarly, the number of negative roots is equal to the number of sign changes in the coefficients of the terms of the polynomial or less than this number by a multiple of 2.
How is Descarte's rule of signs used in simplifying a linear equation to get a quartic in q?
In order to use Descarte's rule of signs to simplify a linear equation to get a quartic in q, you must first use Maple to solve the linear equation and obtain the quartic equation. Then, you can apply Descarte's rule of signs to determine the number of positive and negative real roots of the quartic equation. This can help you in further simplifying the equation or in solving it for specific values of q.
