How can I solve 4y''-12y'+9y = 9(x^2-x)?
  • Thread starter Thread starter Riazy
Riazy
30
This is the problem that has to be dealt with
we are supposed to get the general solution for it
(yh + yp)
Yh is pretty easy,
We get by completing the square of
r^2-3r + 9/4 We get a double root,
Yh = (C1x + C2)e^3x/2
That was pretty easy, and 1/3 is done
now to Yp which is a bit tricky for me
Yp
Yp= Ax^2+Bx+C (Thats what's assumed)
Yp' = 2Ax + 1
Yp'' = 2A
Inserting it all into the the de
4(2A) - 12 (2Ax + 1) + 9(Ax^2+Bx+C) = 9x^2 -9x
I seem to get the wrong coefficients, could someone help me solve the rest of this problem?
detailed explanations are appreciated, Thanks!
Try it! It's not that hard. There's only one x^2 term on each side. Set them equal to each other. What does that tell you about A?
Hmm, I tried, but its an irritating simple error i do somewhere, could you possibly try to solve it too? So I can see how you did it.
I would like to see that irritatingly simple error. We don't solve problems without seeing an attempt on your part. Expand both sides and set the coefficients of equal powers of x equal.
It's good practice to go back through your own work and spot errors.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply . Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
