MHB How can I solve radical equations using the given hint?
  • Thread starter Thread starter mathdad
    Radical
To solve the radical equation sqrt{x^4 - 13x^2 + 37} = 1, substitute x^2 with t, transforming the equation into t^2 - 13t + 36 = 0 after squaring both sides. This allows for factoring and finding the values of t, which are then back-substituted to find x. It's crucial to check all potential solutions due to the possibility of extraneous roots introduced by squaring. The process is straightforward, involving standard algebraic techniques. Ultimately, following these steps leads to the correct solutions for the equation.
mathdad
Determine all of the real number solutions for the radical equation.
sqrt {x^4 - 13x^2 + 37} = 1
Hint given in textbook:
Let x^2 = t and x^4 = t^2
After applying the hint given, do I proceed as usual by squaring both sides?
I have to back-substitute somewhere in the solution steps, right?
Why is it important to always check the answer (s) when dealing with radical equations?
Mathematics news on Phys.org
Yes, it is solving as usual.
You can square both sides, then subtract 1 from both sides.
Factor as usual. Substitute back in.
Try it out and see if you get the correct answers.
Great. Ok. It's not so bad.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
