5) 63 (
5)63 (1
5.
5 .
13.
10.
30
5) 63. (12.6
5 .
13.
10.
30
30
1 + 3x²) 2x ( 2x
2x + 6x³
- 6x³
5)63 (12
A division problem is a mathematical equation that involves splitting a quantity into equal parts. It is represented by the symbol "÷" and is the opposite operation of multiplication.
The steps for solving a division problem are as follows:
1. Write the problem in the correct format, with the dividend (number being divided) on top and the divisor (number doing the dividing) on the bottom.
2. Estimate the answer by rounding the numbers to the nearest whole number.
3. Divide the first digit of the dividend by the divisor.
4. Multiply the quotient (answer) by the divisor and subtract it from the first set of digits in the dividend.
5. Bring down the next digit of the dividend and repeat the process until there are no more digits left.
6. Check your answer by multiplying the quotient by the divisor and adding any remainder. The result should equal the original dividend.
The method you choose (long division or short division) depends on the numbers involved in the problem. If the divisor is a single digit number, you can use short division. If the divisor is a multi-digit number, you will need to use long division.
Remainders are the amount left over after dividing the dividend by the divisor. They are used to show that the quantity cannot be divided equally and there is a remainder that needs to be accounted for. Remainders can also be expressed as a decimal or fraction in some cases.
If you are stuck on a division problem, you can try using tools such as a multiplication table or a calculator to assist with the calculations. You can also ask a teacher, tutor, or classmate for help. It is important to double check your work and make sure you are following the correct steps for solving a division problem.
