How Can I Solve This Mathematical Induction Problem?
The discussion revolves around solving a mathematical induction problem involving the inequality a^n - b^n <= n*(a^n-1)*(a-b). The original poster expresses difficulty in progressing with the inductive step after establishing the base case. Participants suggest that the inequality holds true under the assumption that both a and b are positive. They recommend using algebraic factorization and calculus to prove the inequality, highlighting that the approach varies depending on the relationship between a and b. The conversation emphasizes the importance of assumptions in mathematical proofs and offers alternative methods to tackle the problem.
eric34
Hello folks, I have an induction problem that I have been working on, and I am at my wit's end. If anybody could provide me with a nudge in the correct direction, I would greatly appreciate it. I have attempted to factor out a number of terms to find something remotely intuitive here to present and I just cannot find anything. I've managed to come up with (n+1) > a, though I'm not certain that will even help me. The problem is below.
a^n - b^n <= n*(a^n-1)*(a-b) hypothesis
I used p(1) for a basis step. for the inductive step of p(k+1) I'm really at a loss here. Any thoughts on how I may tackle this, whatsoever, will be appreciated.
You can first prove that \(a^n-b^n=\left(\sum_{i=1}^na^{n-i}b^{i-1}\right)(a-b)\). This can be proved directly by induction or, as explained here, from the formula for the sum of geometric progression \(\sum_{k=0}^{n-1}x^{k}= \frac{1 - x^n}{1-x}\), which can be proved by induction.
Hi Eric34, and welcome to MHB.
For the inequality $a^n - b^n \leqslant na^{n-1}(a-b)$ to be true, I think you will have to assume that $a$ and $b$ are positive. The inequality can go wrong if $a$ or $b$ is allowed to be negative.
If you assume that $a\geqslant0$ and $b\geqslant0$, then the inequality is true. But I don't see how to prove it by using induction.
To prove it using algebra, you can factorise $a^n - b^n$ as $$a^n - b^n = (a-b)(a^{n-1}+a^{n-2}b+a^{n-3}b^2 + \ldots + b^{n-1}).$$ If $b\leqslant a$ then $a^{n-1}+a^{n-2}b+a^{n-3}b^2 + \ldots + b^{n-1} \leqslant na^{n-1}$, and so $a^n - b^n \leqslant na^{n-1}(a-b)$. On the other hand, if $a\leqslant b$ then $a^{n-1}+a^{n-2}b+a^{n-3}b^2 + \ldots + b^{n-1} \geqslant na^{n-1}$. Multiplying by $a-b$ (which is negative) changes the sign of the inequality so again we get $a^n - b^n \leqslant na^{n-1}(a-b)$.
To prove the inequality using calculus, divide both sides by $b^n$ and write $x=a/b$. The inequality then becomes $x^n-1\leqslant nx^{n-1}(x-1)$, or $(n-1)x^n - nx^{n-1}+1 \geqslant0.$ You can check that, for $x>0$, the function $f(x) = (n-1)x^n - nx^{n-1}+1$ has a minimum value of 0, when $x=1$, and is therefore positive for all other positive values of $x$.
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
