MHB How can I use GetUserInfo to get a user's age and name?
  • Thread starter Thread starter Teh
    Function
The discussion revolves around using a function to retrieve user information and display it correctly. The function GetUserInfo is designed to take user input for age and name. The main issue highlighted is the need to call this function properly within the main program to ensure that the variables userAge and userName are populated with user input. The expected output format is specified, demonstrating that if the user inputs "20" for age and "Holly" for name, the program should output "Holly is 20 years old." The key takeaway is the importance of correctly invoking the GetUserInfo function with the right parameters to achieve the desired output.
Teh
I am not sure if should i use a for loop or if statement...may anyone give me a hint what i am suppose to do?Use function GetUserInfo to get a user's information. If user enters 20 and Holly, sample program output is:
Code:
#include <iostream>
#include <string>
using namespace std;
void GetUserInfo(int& userAge, string& userName) {
   cout << "Enter your age: " << endl;
   cin >> userAge;
   cout << "Enter your name: " << endl;
   cin >> userName;
   return;
int main() {
   int userAge = 0;
   string userName = "";
   /* Your solution goes here  */
   cout << userName << " is " << userAge << " years old." << endl;
   return 0;
Testing with inputs 20 and Holly
Expected output: Holly is 20 years old.
Your output: is 0 years old.
Technology news on Phys.org
All you have to do is call [m]GetUserInfo[/m] with the appropriate parameters.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
I am trying to run an .ipynb file and have installed Miniconda as well as created an environment as such -conda create -n <env_name> python=3.7 ipykernel jupyter I am assuming this is successful as I can activate this environment via the anaconda prompt and following command -conda activate <env_name> Then I downloaded and installed VS code and I am trying to edit an .ipynb file. I want to select a kernel, via VS Code but when I press the button on the upper right corner I am greeted...
