How can Line integrals curves not matter?
In summary, a conservative vector field is one such that the integral of a function over the field is always the same no matter what the curve is. However, for some line integrals, the integral depends on the curve between the endpoints.
Noone1982
83
Thanks on the help on the other thread.
I, however, have yet another question. In the line integrals, how is it that we're integrating the various components to the limits of the curves, it seems like the curves really don't matter, just their limits.
Can someone explain how the curves are important too and not just their limits, as many functions can have the same limits ...
This depends on whether you're integrating over a conservative field. If you are, the integral is path independent, but if you're not, then different paths between the same two points yield different integrals.
What exactly is a conservative field? How do the limits change from one type of a field to another?
How would it play into
? Ax dx + Ay dy + Az dz
A conservative vector field is one such that:
[tex]\oint_{C}\vec{\mathbf{F}}\cdot d\vec{\mathbf{r}}=0[/tex]
[tex]\int_{C}\vec{\mathbf{F}}\cdot d\vec{\mathbf{r}}=0[/tex]
Thus rather than following the curve C, you can follow any path.
That should probably read: [tex]\oint_{\gamma}\vec{\mathbf{F}}\cdot d\vec{\mathbf{r}}=0[/tex], where [tex]\gamma[/tex] is any closed curve.
Then, [tex]\int_{C}\vec{\mathbf{F}}\cdot d\vec{\mathbf{r}}[/tex] depends only on the endpoints of C. (That is, any path with the same endpoints as C will give the same value for this integral.)
The first condition can be shown to be equivalent to [tex]\vec\nabla\times \vec F=\vec 0[/tex].
Actually, to me the surprising thing is that for some (actually MOST) line integrals, the integral does depend on the curve!
After all, in beginning calculus, we learn that, to find [itex]\int_a^b f(x)dx[/itex], we find an anti-derivative F, such that dF= f(x)dx and evaluate at the endpoints: F(b)- F(a).
Okay, if we have [itex]\int_C f(x,y)dx+ g(x,y)dy[/itex], why not just find F(x,y) such that dF= f(x,y)dx+ g(x,y)dy and evaluate at the endpoints??
The answer, of course, is that not every (in fact few) "f(x,y)dx+ g(x,y)dy" is an "exact" differential- there may not be such an F(x,y).
But for some such an F(x,y) does exist and it's just a matter of evaluating at the end points- what happens on the curve between the endpoints, or exactly what the curve itself is, doesn't matter.
Related to How can Line integrals curves not matter?
1. How do line integrals curves not matter in scientific research?
Line integrals curves do not matter in scientific research because they are not used to measure the overall shape or structure of an object or system. Rather, they are used to calculate the work done by a vector field along a specific path. This means that the specific shape or curve of the path does not affect the final result of the integral, making it irrelevant in the context of scientific research.
2. Can line integrals curves be ignored in calculations?
Yes, line integrals curves can be ignored in calculations as long as the path of integration does not cross itself or intersect with any discontinuities in the vector field. In these cases, the path must be broken up into smaller segments and the integrals calculated for each segment separately.
3. Why is the path of integration important in line integrals?
The path of integration is important in line integrals because it determines the direction of the vector field and the points at which the function is evaluated. Changing the path of integration can result in different values for the integral, making it a crucial factor in the calculation process.
4. Do line integrals curves have any real-world applications?
Yes, line integrals curves have many real-world applications in various fields such as physics, engineering, and economics. They are used to calculate work, flux, and circulation, which are important concepts in these fields. For example, in physics, line integrals are used to calculate the work done by a force on an object as it moves along a specific path.
5. Is it possible to evaluate a line integral without knowing the path of integration?
No, it is not possible to evaluate a line integral without knowing the path of integration. The path of integration is a crucial component in the calculation process and without it, the integral cannot be evaluated. However, in some cases, the path can be simplified or approximated to make the calculation easier.
  • Calculus
  • Calculus
