How can magnetic field lines snap ?
In summary, magnetic fields around stars or planets can sometimes "snap" and release their stored energy. This happens when a plasma is involved, which creates positive feedback situations that force the transition rapidly. Auroras are created when the magnetic field from the sun and/or Earth is combined with the charge motion in the plasma.
DrZoidberg
522
70
DrZoidberg said:
In astronomy, magnetic field lines around stars or planets are sometimes said to "snap" and release their stored energy.
e.g. the aurora borealis is created that way
http://www.atoptics.co.uk/highsky/auror2.htm
Also gamma ray bursts of neutron stars
http://www.mpa-garching.mpg.de/mpa/research/current_research/hl2006-11/hl2006-11-en.html
So how is it possible for a magnetic field to "snap"?
I'm going to be sorry for taking this on, but here goes:
First off magnetic field lines are bogus and don't exist! They are just a way of imagining fields that came from looking at iron filings but really don't have mathematical validity although one CAN "plot" a field creating drawings of "lines" but all the talk about counting "lines" etc. is really nonsense.
So now that I've said that, let's talk about counting lines! :smile: Lines really are just a pictorial representation of a magnetic field. They show the directions of it in different locations and if you have a number of them they can sort of be related to intensity.
Well, if that's true then how do they "snap"? Well first off, magnetic fields in free space do not "snap"! A "snap" implies something. It implies positive feedback! Toggle switches "snap". Positive feedback generates instability. Hence like a "flip-flop" if you have two stable states, as you edge from one to the other you reach a point where positive feedback takes over and forces the transition rapidly.
Now when it comes to aurora borealis the key is that one is dealing with magnetic fields in a plasma. Plasmas are charged particles. Moving charged particles are currents. Currents create magnetic fields. Hence a LOT of VERY strange things happen in plasmas! And that sets up the possibility of positive feedback situations. The TOTAL magnetic field you view is actually TWO (or more) magnetic fields. The original one from the sun and/or Earth plus the one generated by charge motion in the plasma.
The bottom line is that you find a situation where there are two stable configurations separated by a positive feedback situation. Then as one is slightly moved toward the other the feedback takes over and it "snaps" to the new stable configuration. In this case that configuration produces charge acceleration resulting in the aurora. But without the plasma there are no positive feedback situations and no "snap" will occur.
The "lines" don't really release "their" stored energy when they "snap". What you have is two different stable magnetic field configurations. One has a different energy than the other. When you "snap" from one to the other obviously that difference in energy is either absorbed or released.
Does that help?
Ok, I think I understand what you are saying above ... the lines are just a way of pictorially representing the magnetic flux density, right? So here's my goofy question for you ... if it is just a continuous field (and I agree that it is), then why does the iron filings experiment to "show the field lines" of a bar magnet work? Is there some sort of spontaneous symmetry breaking that goes on to create spatial regions with higher and lower magnetization? Would the same effect be observed in zero gravity using ferrofluid to show the 3-D "pattern of lines"?
@Mods: if this is too much of a diversion from the OP's question, let me know and I'll start another thread.
The magnetic field should be evenly distributed. The simplest explanation would just be that the iron filings are creating their own smaller magnetic fields and attracting to each other, creating gaps between them that actually have nothing to do with the larger field.
Magnetic field lines can "snap" when the energy stored in them becomes too great to be contained. This can happen in a few different ways. One possibility is when the magnetic field lines become twisted or tangled, causing a buildup of energy. Eventually, the tension in the field lines becomes too great and they "snap" back into a more stable configuration, releasing the stored energy in the form of a burst of light or radiation.
Another way magnetic field lines can "snap" is through a process called magnetic reconnection. This occurs when two opposing magnetic fields come into contact with each other. The magnetic field lines from each field can break and reconnect, releasing a burst of energy in the process.
In both cases, the release of energy can create spectacular phenomena such as the aurora borealis or gamma ray bursts. These events are important for understanding the dynamics of magnetic fields in space and can provide valuable insights into the behavior of stars and planets.
In summary, the snapping of magnetic field lines is a natural and powerful process that occurs when the energy stored in them becomes too great to be contained. It is an important phenomenon in the study of astronomy and can help us better understand the workings of the universe.
Related to How can magnetic field lines snap ?
1. How do magnetic field lines snap?
Magnetic field lines can snap due to a sudden change in the magnetic field, causing the lines to rearrange and snap into a new configuration.
2. What causes magnetic field lines to snap?
Magnetic field lines can snap due to a variety of factors, such as changes in the magnetic field strength or direction, interactions with other magnetic fields, or the release of stored energy.
3. Can magnetic field lines snap on their own?
Yes, magnetic field lines can snap on their own without external influence. This is known as a spontaneous reconnection event, where the lines rearrange themselves to reach a lower energy state.
4. What happens when magnetic field lines snap?
When magnetic field lines snap, they release energy and can cause a variety of effects, such as solar flares, auroras, or disruptions in electronic systems.
5. Can we control or prevent magnetic field lines from snapping?
Currently, we do not have the technology to control or prevent magnetic field lines from snapping. However, studying these events can help us better understand and predict their effects.
