How can net force point in the direction of *negative* work?
In summary, the conversation discusses a basic work problem involving two ropes used to lower a 245 kg piano from a second-story window to the ground. The individual forces and work done by each force are calculated, and there is a discussion about the net force and displacement of the piano. It is concluded that the net force must be upwards in order to keep the piano in place and that the piano is in dynamic equilibrium. This is compared to throwing a ball straight up in the air, where the net force is down but the displacement is up.
Kalibasa
It was just a basic work problem:
The two ropes seen in the figure below are used to lower a 245 kg piano 6.0 m from a second-story window to the ground. How much work is done by each of the three forces? (T1 = 1910 N andT2 = 1140 N)
There was a diagram with the angles labeled, and I got the right answers:
w: 14406 J
T1: -9925 J
T2: -4837 J
W= Fcos(theta)d
Fnety= T1y + T2y - w
Actually I got the problem right- T1 and T2 perform negative work and w performs positive work. But when I tried calculating the net force I found that it pointed upwards. This seems contradictory, since the piano has a displacement downwards. How can you have a net force opposite the displacement?
I guessed that if the net force pointed downwards too the weight would be exceeding the tension forces and the ropes would snap; in other words, you have to have a net force upwards so that the tension forces are strong enough to keep the piano in place. Is that right? But then I don't know where the displacement is coming from. Would you say that the piano is in dynamic equilibrium and that it's only moving because you're increasing the length of the ropes?
I'm confused...
Imagine throwing a ball straight up in the air. Neglect friction. While the ball is going up, the displacement is up but the net force (gravity) is down and opposite to the displacement. Note that the speed of the ball decreases as it moves up.
Same thing with the piano. As the piano is lowered its downward speed decreases because the net force (and therefore the acceleration) are opposite to the velocity.
It is correct that the net force in this scenario would point upwards. This is because the piano is being lowered from a higher point to a lower point, meaning it is moving in the opposite direction of the force of gravity. In this case, the net force is the combination of the tension forces (T1 and T2) and the weight of the piano (w). Since the piano is moving downwards, the net force must point upwards in order to balance out the gravitational force pulling it downwards. This does not mean that the tension forces are not strong enough to keep the piano in place. In fact, the tension forces are strong enough to not only keep the piano in place, but also to lower it to the ground. The displacement is coming from the fact that the ropes are being lengthened, as you mentioned. This is how the piano is moving downwards, even though the net force is pointing upwards. Overall, the net force in this scenario is pointing in the direction of negative work because the displacement is in the opposite direction of the net force.
FAQ: How can net force point in the direction of *negative* work?
1. What is the concept of net force?
The concept of net force refers to the overall or total force acting on an object. It takes into account both the magnitude and direction of all the individual forces acting on the object.
2. How can net force point in the direction of negative work?
Net force can point in the direction of negative work when the forces acting on an object are in opposite directions. This means that one force is acting in the direction of motion while the other force is acting against the motion. The net force will then be the difference between these two forces, resulting in a negative value.
3. Can net force point in the direction of negative work even with only one force acting on an object?
No, net force can only point in the direction of negative work when there are at least two forces acting on an object. If there is only one force, it will either be in the same direction as the motion (resulting in positive work) or in the opposite direction as the motion (resulting in negative work).
4. How does the direction of net force impact the work done on an object?
The direction of net force determines the type of work being done on an object. If the net force is in the same direction as the motion, positive work is being done, which means energy is being transferred to the object. If the net force is in the opposite direction as the motion, negative work is being done, which means energy is being taken away from the object.
5. Can net force ever point in the direction of positive work?
Yes, net force can point in the direction of positive work when all the forces acting on an object are in the same direction. This means that the forces are all helping the object to move in the same direction, resulting in a net force that is also in the same direction as the motion.
