polka129
- 43
hello people...i have beeen given this projectile problem to be solved numerically in FORTRAN..i have coded it using runge0kutta 4th order ...now the thing is that i have not been given the end points of time,,;ie. the range.. and i am asked to
a)the maximum height attained by the projectile
what is to b added to the existing code to achive this?
b)the time required to reach the maximum height
c)the time required to return to the original elevation..
i did fortran 4 years ago...havent beeen in practice..this was the lone effort i cud recall...please help...
i have attached the question and the code..
heres the code
CODE
! projectile question *
DATA M,G,C/10.0,9.80665,0.1/
!FIRST i HAVE REDUCED THE GIVEN EQUATION IN TWO LINEAR 1ST-ORDER EQUATIONS
!FOR THE SOLUTION TO PROCEED
F1(T,U1,Y2) = U1
F2(T,U1,Y2) = (-M*G-C*U1**2)/M
!ASSIGNMENT OF VALUES TO CONSTANTS
WRITE(*,*) 'Input left and right endpoints separated by'
WRITE(*,*) 'blank'
WRITE(*,*) ' '
READ(*,*) A, B
WRITE(*,*) 'Input the two initial conditions.'
WRITE(*,*) ' '
READ(*,*) ALPHA1, ALPHA2
WRITE(6,*) 'Input a positive integer for the number'
WRITE(6,*) 'of subintervals '
WRITE(6,*) ' '
READ(5,*) N
WRITE(*,6)
6 FORMAT(12X,'t(i)',11X,'w1(i)',11X,'w2(i)')
H=(B-A)/N
T=A
! the initiaal conditions
W1=ALPHA1
W2=ALPHA2
WRITE(*,1) T,W1,W2
!RK PARAMETER EVALUATIONS HERE
DO 110 I=1,N
X11=H*F1(T,W1,W2)
X12=H*F2(T,W1,W2)
X21=H*F1(T+H/2,W1+X11/2,W2+X12/2)
X22=H*F2(T+H/2,W1+X11/2,W2+X12/2)
X31=H*F1(T+H/2,W1+X21/2,W2+X22/2)
X32=H*F2(T+H/2,W1+X21/2,W2+X22/2)
X41=H*F1(T+H,W1+X31,W2+X32)
X42=H*F2(T+H,W1+X31,W2+X32)
W1=W1+(X11+2*X21+2*X31+X41)/6
W2=W2+(X12+2*X22+2*X32+X42)/6
T=A+I*H
WRITE(*,1) T,W1,W2
110 CONTINUE
STOP
1 FORMAT(3(1X,E15.8))
END
heres the code
CODE
F1(T,U1,Y2) = U1
WRITE(*,*) 'blank'
WRITE(*,*) ' '
READ(*,*) A, B
WRITE(*,*) ' '
WRITE(6,*) ' '
READ(5,*) N
WRITE(*,6)
H=(B-A)/N
T=A
W1=ALPHA1
W2=ALPHA2
WRITE(*,1) T,W1,W2
DO 110 I=1,N
X11=H*F1(T,W1,W2)
X12=H*F2(T,W1,W2)
T=A+I*H
WRITE(*,1) T,W1,W2
110 CONTINUE
STOP
END
