AlphaCrucis
- 10
- 1
- TL;DR Summary
- How can one see the noise in the Fourier Domain if line profile extends passed Nyquist Frequency.
Say we have a transform of a line profile that extends out to the Nyquist frequency such that you cannot see the noise level, what could you change in your spectrograph arrangement that would allow you to see the noise level in the Fourier domain?
My thought is that we can apply a filter, P(s), to remove the high-frequency noise. To do this, we assume that the stellar spectrum and the noise have distinctly different transforms so the stellar signal is concentrated toward lower frequencies whereas the amplified noise signal occurs at higher frequencies and in ideal situations can be readily identified. This works because the instrumental profile was narrow enough to compare to the stellar lines so only modest alterations are involved in the stellar signal AND the signal-to-noise ratio of the observations is high.
Is choosing such a filter, P(s), how we "change the spectrograph arrangement" that allows us to see the noise level in the Fourier Domain? Or is there another way?
